Old 05-28-2008, 06:45 PM   #1 (permalink)
GreatDivide1's Avatar
Arrow Thoughts on abs
hey all im looking to delete my abs....anybody done this???? am getting ready to swap in axles and wont be useing rover peices anymore so no need for abs brain or hardware.... thought concerns ideas or how to's lets here it....
91 G.D.E. project/daily winter driver
93 BMW 325i project/daily summer driver:SOLD:
00 BUELL cyclone custom
http://www.snhlr.org/
GreatDivide1 is offline   Reply With Quote
Old 05-28-2008, 07:13 PM   #2 (permalink)
Rebuilding Rover
ArmyRover's Avatar
find the brake setup off of a non abs rover and swap. If memory serves it's a pretty direct swap.
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 05-28-2008, 07:23 PM   #3 (permalink)
It is a real easy conversion. I used the stuff from a hunter edition. It took about an hour to hour and a half. The hardest part is running the rear lines. It is pretty straight forward. I have a power bleeder for the brakes so bleeding them for me took a few minutes. With out the bleeder it would take just as long to bleed as it did to do the conversion. It stops a lot better then it did with my abs but my booster was bad and I have never been in one that had a working abs system.
skippermccoy is offline   Reply With Quote
Old 05-29-2008, 03:04 PM   #4 (permalink)
hrmm i have been thinking about hydroboost any thoughts....
Old 05-29-2008, 03:55 PM   #5 (permalink)
Rebuilding Rover
ArmyRover's Avatar
There was a thread on this awhile back on discoweb.org
http://snhlr.org/
90 RRC Parts truck
Old 06-01-2008, 12:33 PM   #6 (permalink)
hermanpj's Avatar
Gallery: 4
i have also been thinking of replacing my braking system with non ABS. actually i'd like to go so far as to replace it with a very common GM-based system so i wont have to worry about parts for it. whats stopping me is i am concerned that if a vehicle left factory with ABS in a model year after ABS became required, then won't you be risking failing safety inspectioin if you remove ABS braking from it?
Pat Herman
Old 06-01-2008, 04:54 PM   #7 (permalink)
herman i dont know how it is in tx...but here in nh they check for brake pad wear and thats it...to many makes and models for inspectors to know what each year and model came with
Old 06-02-2008, 10:34 AM   #8 (permalink)
hermanpj's Avatar
Gallery: 4
i think thats pretty much true. maybe then the only other thing to consider is if you get in an accident and you have removed factory installed safety equipment like an ABS system... from an inusrance and liability perspective you could be exposed.
so i think i'll delay doing this to my truck until i upgrade it enough that its really only going to be a trail rig.
Pat Herman
Old 06-07-2008, 01:49 AM   #9 (permalink)
Good call, from a legal point of view you can't fart in your vehicle without some kind of liability issue.
"Your only supposed to blow the BLOODY DOORS OFF" The Italian job 1969.
roverandom is offline   Reply With Quote
Freakishly clean 1990? Thoughts? LegendaryV Range Rover Classic 11 04-15-2008 01:45 PM
your thoughts black and tan Series Land Rovers 11 04-05-2007 07:28 AM
hp and mpg thoughts... VArova87 Discovery Series I 22 05-25-2006 12:38 PM
Thoughts on the Commonwealth SCSL The Lounge 8 01-31-2006 10:56 PM
