Old 11-10-2006, 08:37 AM   #1 (permalink)
Where is my Black Son?
Default Timing chain? Belt?
What is the 3.9V8? Chain? How do I know if I need to change it? I have no record of it being changed? How much does a kit cost, from this site about 300$. http://www.roversnorth.com/store/sea...&Issubmit=True
Is it a hard job? What generally needs to be removed for it to be changed?
Thanks.
1996 Disco 1 SE7- Stock(Awesome sound system) DD/Range Rover hauler.
1990 RRC SWB Camel Trophy Inspired- ARB, Hella's, Bosch's, AR's 15X8, 32"MTR's,Equipe suspension stuff, Skids, waiting for more...
MuddyRangeRover is offline   Reply With Quote
Old 11-10-2006, 08:52 AM   #2 (permalink)
Greg M's Avatar
If I were you I wouldn't worry about it. If its the original chain, then it and the cam shaft are probably due for a change. BUT, its a big job and unless you have the time, money and skill set to do it, I would leave well enough alone.
Greg M
1987 RRC
Rovers haven't made it to the far reaches of the Earth worrying about warning lights.
Greg M is offline   Reply With Quote
Old 11-10-2006, 09:10 AM   #3 (permalink)
Greg's right.... but if you have a lot of time you don't need as much skill. I did it and I have very little skill, but often a lot of time .
You can get a better timing setup for cheaper... http://www.roverparts.com/Parts/9008.cfm
You should get a workshop manual. It will answer a lot of your questions.
http://www.roversnorth.com/store/p-6...r-1987-91.aspx
Kevin
88 RRC "Audrey"
Old 11-10-2006, 09:14 AM   #4 (permalink)
Ok, thanks for the replies guys!
I wasn;t sure if it was something that HAD to be done. I know with BMW's, if your T-belt goes, you are pretty much guranteed needing a new head. Just wanted to know whether or not that is the case with the Rovers too. If it snaps(can it even do that), will it cause any damage? What is the worst that could happen to that chain?
Kevin you just reminded me that I had CD manual that came with the truck, Ill try and browse through it.
Old 11-10-2006, 09:24 AM   #5 (permalink)
When I changed mine it was missing a lot of teeth. I've heard they can break (the original are plastic) and you would be looking at a lot of work.
Here's a link to most of the manual for download http://www.landrover.ee/est/varia/downloads/cars.htm
Here's a pic of my old cam gear
Kevin
88 RRC "Audrey"
Old 11-10-2006, 09:24 AM   #6 (permalink)
Greg M's Avatar
Kevin is right, the sproket on the camshaft is plastic. The chances of the chain snapping are slim. Never heard of one myself, but i'm sure it has happened somewhere at some time. Belts on the other hand do break and should be replaced at the recommended time. Belts are BS, the only reason for them is they are quieter than a chain or gear. And yes to answer your question, if by some remote chance it did snap, the valves will drop and the piston will probably bend them. Anyway, don't worry about it and go enjoy your rover.
Greg M
1987 RRC
Old 11-10-2006, 12:56 PM   #7 (permalink)
Wear in the chain shows up in poor performance, backfiring at start up & erratic ignition timing. The teeth can break as shown, but the engine runs so poorly by then, it is normally caught before they shear off completely.
Chain is under a cover behind the water pump. If you're in there, think hard about doing the cam, lifters, water pump of course. All wear items.
CJH
1990 Rangie
Philadelphia, PA
choffa@comcast.net is offline   Reply With Quote
Old 11-10-2006, 04:48 PM   #8 (permalink)
yieldsign2's Avatar
Well, chalk one up for it happening...
My 87 slipped or broke its timing chain and i only went as far as top pull the cam covers and see broken rockers and such..
Devon Yablonski
1989 Range Rover Classic - Running and Muddy
1988 Range Rover Classic - Parts
http://ads.auctionads.com/pagead/lin...assZyieldsign2
yieldsign2 is offline   Reply With Quote
Old 11-11-2006, 05:55 AM   #9 (permalink)
All right,t hanks guys. Won't worry about it for now until i start noticing those symptoms.
