Old 05-21-2006, 06:49 PM   #1 (permalink)
I love to use my ...
User's Avatar
Default Tire question !!!
I need to get tires for my (new ) 1994 LWB Range Rover.
I've read alot on rangerovers.net and on the forum but I don't know what size to choose... I've got a deal on BF Goodrich All-Terrain T/A and I am looking for these 3 sizes:
- 225/70RR16 C
- 225/75SR16 D
- 235/70QR16 C
Wich size should I get ? I have the air suspension and I am planing to keep it for the moment ... I live in Canada, so that means chances of heavy snow and I want to off road in the summer.
Thanks in advance !
Guillaume
User is offline   Reply With Quote
Old 05-21-2006, 08:27 PM   #2 (permalink)
Rocky Mountain High
Funrover's Avatar
well.... they are all close to same.. I run 235 85 r 16 BFG AT's
Old 05-21-2006, 08:49 PM   #3 (permalink)
ภาษาไทย
llesra's Avatar
Gallery: 16
all three sizes are within fractions of an inch of each other. all would work. i say get the 235/70/16 just because its the widest. shouldnt rub or anything on your rrc.
Arsell
My Car Domain Site
llesra is offline   Reply With Quote
Old 05-21-2006, 09:26 PM   #4 (permalink)
Ian Matthews
p76rangie's Avatar
They will all fit fine, but your speedo will be out.
Ian
p76rangie is online now   Reply With Quote
Old 05-21-2006, 09:33 PM   #5 (permalink)
RageRover's Avatar
Ian
Ever since I mounted the 255's on the RRC, my speedo reads 5 mph faster than what I am actually going. I got used to it.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 05-22-2006, 04:51 PM   #6 (permalink)
User's Avatar
Great thanks ! As for the speedo, I can deal with that ...
Old 05-22-2006, 06:43 PM   #7 (permalink)
Rocky Mountain High
Funrover's Avatar
I pretend I am going faster also!!! LMAO!!!
Old 05-22-2006, 07:38 PM   #8 (permalink)
Hey, if you want to save a few bucks, I have a set of four BF Goodrich Long Trail 235x70x16 tires I could sell you at a great price. They can be seen here :
http://homepage.mac.com/paulgrant/PhotoAlbum20.html
You can contact me at:
paulgrant@mac.com
Thanks,
Paul
Old 05-22-2006, 07:56 PM   #9 (permalink)
Ian Matthews
p76rangie's Avatar
255's will have the car going faster than the speedo, not visa versa. Bigger tyres are the quickest way to get booked for speeding.
Ian
Old 05-22-2006, 08:36 PM   #10 (permalink)
Choqiees's Avatar
Ian
remember...it's a Land Rover
2002 Discovery II SE
1999 Range Rover P38 HSE
Old 05-22-2006, 08:41 PM   #11 (permalink)
Rocky Mountain High
Funrover's Avatar
Old 06-05-2006, 09:55 PM   #12 (permalink)
ryans ROVER
ryanc8514's Avatar
i put some 285/75/R16 radial all terrains on my 94 rover an they barely fit, i have the old man emu suspension so it gives me a little more clearance but so far i love the tires...i only put 2 on the back because the other ones wont fit on the front, steering becomes pretty sensitive at high speeds bc the front tires are smaller an skinnier
ryan mura
1994 range rover county lwb
-BIG BLUE 3" coil spring suspension lift
-Procomp ES3000 shocks
-custom snorkel
-glasspack exhaust system
-285/75/R16 all terrain tires
-old school CB radio from the 80s-cobra
-speakers loud enough to set off car alarms
-LR3 side air vent
ryanc8514 is offline   Reply With Quote
Old 06-06-2006, 04:05 PM   #13 (permalink)
ภาษาไทย
llesra's Avatar
Gallery: 16
does that mean you have the 285/75s in the back and the stock size in the front?!?
Arsell
My Car Domain Site
Old 06-06-2006, 04:55 PM   #14 (permalink)
ryans ROVER
ryanc8514's Avatar
the front tires are slightly larger than stock, they are 255/75/r16...it looks pretty obvious that the back tires are larger than the front, im going 2 put the new 285s on the front 2 once i install my big blue springs
ryan mura
-custom snorkel
-LR3 side air vent
Old 06-06-2006, 08:29 PM   #15 (permalink)
Greg M's Avatar
Ryan, you shouldn't run two different size tires on a four wheel drive. They rotate at different speeds and cause great strain on your differentials. You have almost 2" difference between the tires.
Now, one more thing to think about when going to bigger tires. An inch or two difference in tire diameter will effectively change the gearing. Rangies are already geared fairly high at 3.54. If you go with really big tires (for example 285/75/16 which is basically a 33") you will effectively drop your gearing to 3.13. This is pretty tall for a heavy vehicle with a small V8.
Just food for thought.
Greg M
1987 RRC
Rovers haven't made it to the far reaches of the Earth worrying about warning lights.
Greg M is offline   Reply With Quote
