Old 04-25-2006, 09:31 AM   #1 (permalink)
M. Hensley
mensley's Avatar
Exclamation Tons of problems...
My RRC has been giving me trouble
*first off, about everyother time I start driving, when I hit the accelerator, I just creep along at about idle speed for around 5-10 seconds before I get power --->if I take my foot off the gas while moving, I start this process all over again. Will often flat out die--> see below
*&, if I sit at a stop light for long enough it will lurch when I hit the gas & die.
*&, when I park it after a stressful drive, and let it sit with the engine running, it will behave for a minute or so before the engine starts reving itself on its own all the way up to about 1700rpm's... if I touch the gas pedal, the engine cuts off & will not start for anywhere from 2-45 minutes
*& my engine warms up rather fast, (see new parts below)... I am going to change the thermostat this weekend... after that?
In the last week, I have replaced the fuel filter, fan & clutch, air filter, ignition cap, rotor, wires and coil.
-Mason
Help????
mensley is offline   Reply With Quote
Old 04-25-2006, 10:07 AM   #2 (permalink)
daway's Avatar
my RRC did does that to (the 1st part) were it takes a second or 2 to get some power, but it has not done that for awhile? mustly in the winter. i changed the breather filter (pcv valve cover ventilator) after i did that i felt the RR get a faster pick up. i read that could cause major oil leaks (if it is to clogged)www.rangerover.net. i don't think would be your anwser? i had alot done to it in the last month, oil coolent line replaced, and ect. other filters u could check if your tune in up your RRC, rocker cover filter (small round filter), air intake filters (3) above hood (my filters above hood were falling apart). let me know what u find out.
Old 04-25-2006, 10:35 AM   #3 (permalink)
OkieRover's Avatar
Gallery: 2
Did you clean the Air Idler Valve?
http://www.okierover.com/images/idlervalve.jpg
I punch my clown daily.
Old 04-25-2006, 11:34 AM   #4 (permalink)
daway's Avatar
how is the best way to clean this valve? i should check this out this wkend. would this help improve lack of power when i first start to go?
2001 X5 3.0i "dodi"
1993 RRC, county LWB "bertha"
myroverworld
Old 04-25-2006, 01:18 PM   #5 (permalink)
M. Hensley
mensley's Avatar
I already cleaned that... & it runs better when it is cool outside
Old 04-25-2006, 01:25 PM   #6 (permalink)
OkieRover's Avatar
Gallery: 2
I know that the seal there is important to idling and running.
Just use some brake cleaner on a rag. Clean the piston point and try to clean the seat inside the plenum.
Old 04-25-2006, 01:26 PM   #7 (permalink)
OkieRover's Avatar
Gallery: 2
Where'd you get that ignition cap?
Are you sure its the right one. There were some posts about this problem on the board last month.
Old 04-25-2006, 05:32 PM   #8 (permalink)
It's all about my Blue Balls!
JungleRR's Avatar
Help????
I had all of the above problems also! I changed th thermostat and I have not had a problem since. It starts well and keeps going without dying. I think you'll be really happy after changing it!
Silly Boys!... Range Rovers are for girls!
Cars:
1988 Range Rover Classic (aka Blue Balls)
2000 Discovery II SE7 (my fiance's... soon to be mine)
JungleRR is offline   Reply With Quote
