Going to start rebuilding the top end of my 3.5. I have new cam, lifters, rods, and timing chain coming along with all the needed gaskets. I'm going with composite gaskets on the heads and intake. And the rubber gaskets on the valve covers.
So my first batch of questions (I'm sure I'll have a lot more to come), what other supplies do I need? I know I need Vaseline for the oil pump, Loctite for some bolts, and antiseize for others, but what other odds and ends will I forget?!? Do I need new valve cover screws with the rubber gasket? What is good way to clean up the inside of the engine and parts that are going back on? And a Big Thanks to Okie and GregM for the encouragement in my previous post. ![]()
Kevin 88 RRC "Audrey" |
Buy lots of carb spray to do your cleaning of parts and surfaces. I would also suggest you do a really good engine flush, prior to tearing the engine down, to help get rid of alot of old engine build up.
Mike |
#4 (permalink) | |
#5 (permalink) | |
good luck w/ the project!! show some pic's when u get it going!
2001 X5 3.0i "dodi" 1993 RRC, county LWB "bertha" 1991 RRC (dad's), parting out (email me or check out the link below) myroverworld |
#8 (permalink) | |
#9 (permalink) | |
Mike |
#10 (permalink) | |
#11 (permalink) | |
Not sure about the size. I remember 2 of them were longer than the rest. LR claims you're supposed to replace these when using the new style intake gasket (composite). |
#12 (permalink) | |
The HD way to go is to drain out you engine oil and fill the crank case with ATF, let idle for 20 minutes or so and drain. No harm to the engine and boy does it clean. Mike |
#13 (permalink) | |
Series Moderator
I also dont recommend the vaseline in the oil pump either it does work but does take too long to flow oil and that breif period of starvation can do damage rapidly,a better technique is to make a tool for use with a power drill simply a 1/2 inch length of bar stock with a slot cut in one end to accept the oil pump drive shaft with the distributor removed slot the tool over the oil pump drive and spin it with the drill till oil fills the pump mind your wrists it can jolt when you start getting pressure oh and if you put a bit of hose pipe over the end of the tool it keeps the pump drive and tool inline. Cheers ONz |
#14 (permalink) |
Well I got her opened part of the way. There's soooooo much stuff you have to take off just to get at the engine! Did my best to clean her both inside and out, but she is so filthy. Did an engine flush with ATF and washed her down with Simple Green. Probably could have used something stronger on the outside, but I'll just spend some more time cleaning the parts while they are off.
After about 10 hours counting cleaning,draining, lots of note taking & labeling, got all the way to the intake manifold and valve covers off. I have a lot of cleaning to do. Tomorrow, I hope to have the rest off which includes the heads, water pump, front cover and cam. Oh, and drop the sump pan. And start on cleaning everything. I think I need to go out and buy a case of carb cleaner! I also got all my parts in today. If all goes well, I'll start putting her back together on Friday and Saturday. Here's a few pics of the mess! And one of my work space which includes a shade tree!
#15 (permalink) |
Take a browse through RPI's site. Plenty of good information on the Rover engine:
http://www.rpiv8.com/ For cleaning, especially the tough varnish & hardened sludge, get some paint stripper with methylene chloride (Home Depot). Works great, but use outside & with rubber gloves. Oven cleaner is another good & cheap cleaner for really tough stuff, but be careful on the aluminum, leave it too long & it will etch the surface.
CJH 1990 Rangie Philadelphia, PA
