I have a 1989 range Rover 3.9L with lots of miles.
I have just put a tune up in new plugs wires and cap and rotor. when the car is cold or has sat for more than an 1 or 2 hours. It idle is very uneven and the car stalls out. But once it is up to temp it runs fine. The tune up has helped. Where do i go now |
![]() Join Date: Dec 2005
Is the ignition been timed? After the new rotor and cap? Might wanna check it out to be sure.
![]() Then again, you said after it warms from a cold start, it runs fine, so a bad temp. sensor on the thermostat housing could be throwing of the computer, and making it run rich, also bad Oxygen Sensors. Just not too long ago, I tested my O2 sensors at my college shop, found the sensors, run the motor slightly rich, but not too bad, either way, I have to replace them. See if you can have a shop test those sensors. I don't think the MAF sensor, or IAC motor have to do with your matter, but about the IAC motor, you can find in this forum how to clean it, I think OkieRover has an article about how to clean it. BTW IAC is Intake Air Control, also a Valve, keeps your idle up in some cases. Have these things looked into, and hopefully it will solve your problem. ![]() And Welcome to LRO man! ![]()
Check that Air Idler Valve first.
It don't cost a thing to clean. |
