Old 12-28-2006, 05:21 PM   #1 (permalink)
campbell's Avatar
Default valence question
Does anyone know how involved it is to remove the valence panel on a 95 RRC? i am planning on using the existing fog light harness and wiring to put in aux. lights in the mounting holes on top of the bumper, but I cant figure out hoe to bolt them on without taking the bumper off? There is no way to thread the respective lock washer and nut without doing so.
Any advice?
campbell is offline   Reply With Quote
Old 12-28-2006, 05:57 PM   #2 (permalink)
Take your grille out (two clips in front of radiator). That will give you access to the back side of the bumper. When drilling holes, be sure to center punch the location first, chrome is very hard, drill will wander without a good starting point.
Not enough room, bumper is easy to drop, disconnect end caps from fender, then nuts on back side of bumper.
CJH
1990 Rangie
Philadelphia, PA
choffa@comcast.net is offline   Reply With Quote
Old 12-28-2006, 06:42 PM   #3 (permalink)
campbell's Avatar
Thanks.
I have the day off tommorow, so I will hit it in the morning.
appreciate the help.
