Old 11-18-2006, 08:35 AM   #1 (permalink)
rover carpenter
Default valve cover gaskets
hello all, i am starting to replace the valve cover gaskets as we speak. 1995 classic lwb. the thick range rover repair bible i have is pretty vague. it looks pretty cut and dry. any tricks to it? i will be checking periodically for any posts. thanks in advance. jim
BIG JIM is offline   Reply With Quote
Old 11-18-2006, 03:06 PM   #2 (permalink)
DougG's Avatar
I just replaced the VC gaskets on my 88 RRC, and have replaced the VC gaskets on my P38 RR before. The right side is very easy, just a few bolts, and then you have to wiggle the cover off. Take off the old gasket, clean all mating surfaces, and then put it back on. The left side is a PITA. You have to move a lot of stuff to get to it, but it is do-able.
DougG is offline   Reply With Quote
Old 11-18-2006, 07:02 PM   #3 (permalink)
rover carpenter
thanks doug, i just finished. went pretty sweet. i am gonna do the sea foam thing tomorrow, then dump the oil and pull the pan and clean up inside there. there was some sludge when i pulled the vcg. i cleaned up the best i could and sprayed carb cleaner on it all and cleaned again. i am a little thirsty now. thanks again. jim
