Old 07-14-2008, 06:06 AM   #1 (permalink)
Default Varying idle speeds - what's the culprit? 95RRCLWB
When I start up my 4.2L 95RRC, the RPMs jump to like 1500 then down to some RPM (sometimes 500, sometimes 600, sometimes 900, etc.). If I drive for a while and stop a light it could read 500 and barely idle. The next light I come to it could be 1000 or 900 or 700 or whatever. Is this behavoir normal? If not, any idea what's causing it? The IAC valve is fairly new and clean (so is the seat where it sits), the T piece and hoses are clean, and the base idle has been adjusted.
Appreciate all help!
deadboy1977 is offline   Reply With Quote
Idle Control Valve - idle problems; get to know it glenncof Range Rover Classic 2 02-24-2008 12:57 PM
Advice on setting base idle norville Range Rover Classic 6 02-23-2007 12:22 PM
NYTimes: Is 8 Enough? Transmissions Meet the Need for Speeds Adam in NYC USA General Land Rover Discussion 6 09-16-2006 08:21 AM
