» Sponsors
» Sponsors
Old 10-14-2009, 01:28 PM   #1 (permalink)
Default Weird issues even for a RR classic
last week i was driving along just fine, all of a sudden my engine is dead and i coast to a stop along the side of the freeway, i get it towed home and start doing some basic checks, i discovered that the top ECU under the passenger seat had become disconnected, so i connected it and it started up, problem solved right?
on monday i was driving along and it died again, i pulled over to the side of the road, tried starting it and it started right away, then on tuesday i was driving and it died again, I did the same thing i did the other day and it started up i drove it all of 200 ft when it died again then wouldn't start, I spent all yesturday checking all sorts of things, I discovered that the rotor had an earth fault, i replaced it and it started! problem solved right???? it died about 5 minutes later and it would start and die almost immediatly, then sometimes no start and every onceand awhile it would start then die agian,, then an hour later it started up and has been running fine for about 15 minutes now, I can't understand it!
the PO had replaced the cap, rotor, and plug wires with blue ones, i'm unsure of the brand but they are the newest looking thing in the engine compartment...
reverand_redbeard is offline   Reply With Quote
Old 10-15-2009, 11:15 AM   #2 (permalink)
Jeep Slayer
GoGetTheHorzion's Avatar
it could be a cooling sensor problem. Id check into the cooling system. Or take a look at your EFI computer, under the left seat, you may need a new one.
live fast die young
GoGetTheHorzion is offline   Reply With Quote
Old 10-15-2009, 11:21 AM   #3 (permalink)
Jeep Slayer
Did you replace the plug wires in the correct order? my buddy did that wrong once and the damn truck nearly blew up.
live fast die young
Old 10-18-2009, 02:05 PM   #4 (permalink)
Fuel pump?
johnkolesar is offline   Reply With Quote
Old 10-18-2009, 02:38 PM   #5 (permalink)
ihscouts's Avatar
Maybe the ECU connector is bouncing/disconnecting. I'd take another look at the clip to make sure it's secure, nothing is broken. Check your grounds for corrosion too.
97 D1 SD
ihscouts is offline   Reply With Quote
Old 10-18-2009, 05:59 PM   #6 (permalink)
i am doing the ignition amplifier replacement with a chevy one, now i have good spark blue, before it was weak and yellow, but the car wont start up, i think my rotor might be bad, when i do the ignition test in rave, it says to hold the coil contact above the rotor and waatch for sparking, i see spark going from the coil wire to the rotor then jumping to the distributor case, does should the rotor itself provide the ground? could the rotor have an earth fault?
Old 10-18-2009, 07:45 PM   #7 (permalink)
ihscouts's Avatar
Nope, not a good thing. spark goes to each termial. The spark plugs are ground. Wipe your rotor and inside of cap with ammonia, it will remove the carbon tracks.
97 D1 SD
Old 10-18-2009, 08:23 PM   #8 (permalink)
i get good spark at the pulgs as well, just something for one reason or another it wont start, I replaced the stock amp module with a napa module made for an S10 i believe, it definantly helped the spark get stronger, however it seems like the timing is off, it seems to catch every once and awhile but it never gets up and running on its own power. are there any adjustment that can be made?, I think the spark might be jumping to one of the bolts that holds the flash guard on, i might try putting some dielectric grease over the bolts and replacing the rotor with one less rusty inside....
I cleaned the cap with contact cleaner i might try the amonia thing but i don't think thats the issue
Old 10-19-2009, 10:38 AM   #9 (permalink)
ihscouts's Avatar
After rereading your posts your probably right. Have you ruled out the fuel pump?
97 D1 SD
Old 10-19-2009, 10:44 AM   #10 (permalink)
yeah i can smell fuel coming out the exuast when i crank it over, as well as getting some fuel when i pulled the hose off the return line on the fuel rail, i wish they had schraider valves on 93s that would be so easy! I'm sure it has to be the rotor, i had a new one which broke right away, but after i did the module swap it ran for a couple minutes but it was rough, i had some plug wires in the wrong order i think, so i redid it all but i also managed to break my new rotor, i put the old one in and it hasn't started since, it has to be the rotor thats the X factor in all this....
Old 10-19-2009, 11:15 AM   #11 (permalink)
ihscouts's Avatar
Do you have a manual or the RAVE CD? Clockwise distributor rotation firing order is; 1-8-4-3-6-5-7-2, counter-clockwise distributor firing order is; 1-2-7-5-6-3-4-8. Facing the engine and from front to back cylinders; 1, 3, 5, 7 on your right; 2, 4, 6, 8 on your left.
97 D1 SD
Old 10-19-2009, 11:21 AM   #12 (permalink)
hmmm i didn't know there were clockwise and counterclockwise distributors, but the wire placement is the same either way i'm assuming...
Old 10-19-2009, 11:25 AM   #13 (permalink)
ihscouts's Avatar
I own a 97 D1 4.0 without a distributor. I don't know which way yours rotates so I covered the bases.....LOL.
97 D1 SD
Old 10-19-2009, 11:36 AM   #14 (permalink)
well i am gonna wait untill tomorrow when oriellys gets the rotor in, hopefully it starts!
Old 10-21-2009, 03:57 PM   #15 (permalink)
Any updates??? Let's get this thing running before you part it out & get more in debt with another Rover.
Most people say you have to a Genuine Lucas rotor and the other rotors may work for a short time then crap out. Did you f*ck up the dissy springs when pulling the old rotor?
Have you double checked the firing order? If you haven't, try cleaning the plugs incase they have become fouled from all the starting attempts.
One more thing to check is your coolant temp sensor (the one to the ECU). Could be on its way out providing a bad signal. This will produce a bad fuel/air mix making it hard to start.
What year RRC do you have?
Kevin
88 RRC "Audrey"
Range Rover Classic Part 4 Sale DarkTari Land Rover Parts and Accessories 3 11-13-2009 06:47 AM
1995 range rover classic several issues. tebelleh1 Range Rover Classic 3 04-08-2009 08:15 AM
Weird brake issues, need help!! akwagon Discovery Series II 2 02-29-2008 09:24 AM
1990 Classic with brake and elec issues Help!! skippermccoy Range Rover Classic 6 11-07-2007 06:12 PM
Steering issues - 1992 Classic dbrisotti Range Rover Classic 10 12-04-2005 11:54 PM
