What is the best way to lift the body off the frame? - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 01-03-2013, 06:29 AM   #1 (permalink)
The type to cop a Range along with all the features
greenmountainski's Avatar
Default What is the best way to lift the body off the frame?
Is there a way to do it without taking the headliner out? I have a big backhoe to use to lift.
Now I'm in the RANGE, switchin' lanes doin a buck'n CHANGE
greenmountainski is offline   Reply With Quote
Old 01-03-2013, 07:12 PM   #2 (permalink)
enterusernamehere's Avatar
I'd read a thread of some guy in aussyland opening all of the windows, throwing some timber through them, and chain to lift them. That should work without damaging the headliner, unless I'm missing something.
enterusernamehere is offline   Reply With Quote
Old 01-04-2013, 11:06 AM   #3 (permalink)
I do think that would work now that I look at it. At first I didnt think it would but with the doors closed and the window down the weight goes on the windrow frame. I wonder how balanced that is going to be.
Old 01-04-2013, 11:40 AM   #4 (permalink)
Keanan's Avatar
If it is unbalanced you can always through a few sandbags, old tires or bricks in the back or on the front bumper to balance it out.
Sent from my iPhone using AutoGuide.com App
Keanan is offline   Reply With Quote
Old 01-04-2013, 11:43 AM   #5 (permalink)
Very good idea
Old 01-08-2013, 05:30 PM   #6 (permalink)
grnthng's Avatar
What are you trying to do? Body mounts or are you trying to seperate completely?
It does not sound like a good idea to bare the weight of your body on the very fragile top and or upper door frames.....unless you have a different body going back on it?
The way i've seen it done on you-tube a few times is bracing from under the rockers and then simply wheeling the frame out from underneath!
The rockers are the strongest and best balanced!
grnthng is offline   Reply With Quote
Old 01-08-2013, 07:16 PM   #7 (permalink)
I already did it with a strap and the bucket loader forks, seemed to be fine except for the bent gutter on both sides!
Old 01-09-2013, 01:39 PM   #8 (permalink)
grnthng's Avatar
Yhea,, hopefully you didn't warp the door frames to cause wind noises when driving or water to get in between the weatherstrips and frames!
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Body lift or suspension lift.... Sam_0921 Discovery Series II 14 10-15-2011 11:12 AM
Will a RRC SWB body fit onto a Disco frame? highfructosecornsyrp Range Rover Classic 5 08-10-2011 10:03 AM
Body Lift Mader89 Range Rover Classic 2 10-25-2010 05:26 AM
Series IIA body to a Disco I frame..? extremrovers Series Land Rovers 3 04-15-2009 05:58 AM
Rear tailgate lift gate frame thingy OkieRover Range Rover Classic 6 09-05-2005 07:09 PM
SEO by vBSEO 3.3.2
