Old 12-09-2006, 04:15 AM   #1 (permalink)
Default what engine oil
what engine oil should i put in my 1990 3.9 v8 rangie
wayno is offline   Reply With Quote
Old 12-09-2006, 04:24 AM   #2 (permalink)
Where are you?
Kevin
88 RRC "Audrey"
Old 12-09-2006, 06:02 AM   #3 (permalink)
Where do you live, give us some help here.
Old 12-09-2006, 08:33 AM   #4 (permalink)
live in uk.
Old 12-09-2006, 01:22 PM   #5 (permalink)
bargecapt
Default castrol 10-30
Originally Posted by wayno
live in uk.
i don't think you should have a problem with castrol 10-30 or 10-40. in all of the cars i have owned, i would use castrol 10-30 in the winter, and 20-50 in the summer
bargecapt is offline   Reply With Quote
Old 12-13-2006, 09:59 AM   #6 (permalink)
daway's Avatar
i use the castrol 20-50 in the summer and 5-30 in the winter (MN). check your owner manual and see where the temp of your area fits in. 20-50 can go down to 40 or so degrees F. i think if i move to OR next summer (hope so!!) i will stay w/ 20-50 in summer and go w/ 10-40 or 10-30 in the winter months (going in the mountains, colder) but not as cold as MN (-20F w/out windchill at times)!!
also buy some oil flush and add it in before you drain the oil (clean it's out good). i do that every other oil change.
2001 X5 3.0i "dodi"
1993 RRC, county LWB "bertha"
myroverworld
