Old 05-05-2005, 05:20 AM   #1 (permalink)
Default What is a good front brake pads?
I am in need of replacing front brake pads on my 95 LWB and want to see what brand has low dust and noise free pads.
Thanks.
AdrianL is offline   Reply With Quote
Old 05-05-2005, 08:09 AM   #2 (permalink)
hamrendan's Avatar
Default Brakes.. ask a pro.. ( not me! )
Thats funny, I always look for low dust pads for my Audi's, but the thought never accured to me on the rover.. probably because less dust equals less bite ( maybe not so true in newer generations of pads )... I have always had good luck with Padgid.. not sure if they make them for the Dubs.. Lockheed I think is the maker of the original pads.. I think British Pacific had a special on pads on thier deal of the day last week.. Anyway, Call them up they will get you a good deal on what ever type of pad you decide on.. Remember there is a WIDE price range for these pads.. good pads will set you back more.. I remember buying a complete set of Lockheed pads for $68 bucks about 6 years ago..They will also give you good advice on which ones are right for your type of driving.. You can probably pick up a cheap set from NAPA too.
Here is my advice on the noise,,, The PO on my Rover had put 2 of the pads on the wrong side.. there is usually one side of the pad that is cut at an angle to avoid making the pad chatter ( which causes the noise ) this cut edge should be the leading edge as the rotor turns into it. Also, if your pads do NOT come with a backing on top of the metal plate, then its a good idea to put some brake pad anti squeal on the back of the pads, at least a few hours before you put the pads on.. ( 24 hours is better ) .. If you do both of those things you will have noise free pads for the duration of thier service life..
Ohh and get a MOTIVE power bleeder.. they are the best!!... Best $40.00 investment I have ever made..
Dan Hamren
93 LWB "Dubya" AKA "The Beast"
hamrendan is offline   Reply With Quote
Old 05-05-2005, 09:04 AM   #3 (permalink)
Default Thanks for the advice.
It is just that there are wide range of pads and brands but wanted to make sure I am getting the best one.
Old 05-05-2005, 10:28 PM   #4 (permalink)
Landy-Andy's Avatar
Default Brake pads....
Hi AdrianL
Cant really help you with selecting a brand...but,
I have noticed that a lot of after-market pads dont have the little wires that plug into the brake wear sensor plug.
They fit & work just fine, but you will not have any sensors working that will tell you when they are worn down to "replace" level.
Just a thought before you go shopping...
Andy
Landy-Andy is offline   Reply With Quote
Old 05-06-2005, 03:09 PM   #5 (permalink)
I have found Mintex brand made in England work well and don't squeak. They cost abot $40 to $50.
lonestarrover is offline   Reply With Quote
