Old 03-26-2005, 03:24 PM   #1 (permalink)
Default Where can I get the upper steering shaft u-joint?
I need the upper and lower u-joints on my steering shaft. I figured that I might as well change out the rubber coupling while I had it out. Where can you get the upper u-joint? I can find the coupling and lower u-joint anywhere, but the upper one seems to be scarce. It looks like most of the complete shafts that are advertised are only the lower section. Does anybody know? Thanks.
TNRRClassic is offline   Reply With Quote
Old 03-26-2005, 07:09 PM   #2 (permalink)
What year Classic are you talking about?
lonestarrover is offline   Reply With Quote
Old 03-27-2005, 04:56 AM   #3 (permalink)
Gowyn's Avatar
Try Paul Safari Compnonents at 905.262.4448
Gowyn is offline   Reply With Quote
Old 03-27-2005, 07:38 AM   #4 (permalink)
Sorry for the lack of info. It is a 1987.
Old 03-27-2005, 10:28 AM   #5 (permalink)
Atlantic British
http://www.roverparts.com/ProductLis...=20&CurPage=10
Old 03-28-2005, 05:43 AM   #6 (permalink)
Default Rovers North
www.roversnorth.com
They are #1 supplier for RR Classic components in North America.
AdrianL is offline   Reply With Quote
Old 03-30-2005, 07:29 AM   #7 (permalink)
LRR219's Avatar
Generally Its Not A Part That Is Sold Seperatly, Its Sold As The Upper Steering Shaft Only, You Can Get The Lower Joint Seperatly But As For Just The U-joints, You Are Outa Luck From What I Have Ever Been Albe To Find, I Stole One Off A Retired Rover! Might Be Your Best Bet!!!! Best Of Luck
Don't follow us, you'll get stuck.
LRR219 is offline   Reply With Quote
Old 03-30-2005, 02:52 PM   #8 (permalink)
glenncof's Avatar
http://www.rangerovers.net/rrpartsv.htm
always look here for parts recommendations
glenncof is offline   Reply With Quote
