#2 (permalink) | ||||
Rebuilding Rover
not a good start, what color is the fluid does it smell burned?
get your brakes fixed nothing better than having them fail and kill someone....Quote:
The part that confuses me and maybe I miss read this. Are you continuing to drive the Rover with the tranny acting like this? If you are stop, if it's damaged your just making it worse and if it wasn't damaged your doing it in. Get it diagnosed don't put it off.![]() Used transmissions can usually be found for 3-4 bills so don't give up on a good RRC if that's all it is.
"Only two defining forces ever offered to die for you, Jesus Christ and the American G.I. One died for your soul, the other for your freedom." http://snhlr.org/ 91 Range Rover Classic 90 RRC Parts truck 94 Saab gas mileage beater
long live the mullet
Could be a few things...
Did you check the fluid level? Usually no movement is an indication it may be low, and then expands as it heats up, to the point where the filter can gain suction. Could also be a drainback issue, where the fluid drains out of the converter after an extended period of time and it loses charge. See if the fluid level is extremely high on the stick before the next time you start it. Another possibility is that somehow you lost the tube from the bottom of the filter. |
Rebuilding Rover
sometimes I wonder if anyone reads what people put or they just throw a answer out there...
#8 (permalink) | |
Rebuilding Rover
That's what I mean the answer was in your original post ![]()
| Thread Tools | |
| Display Modes | |
| Loss Of Power | KETJAMAICA | Discovery Series I | 2 | 03-10-2007 03:06 PM |
| Loss of power!!!!! | Kevin88RRC | Range Rover Classic | 8 | 10-16-2006 07:58 AM |
| 97 Disco- check Engine Light on and rough running - loss of power | lajilana | Discovery Series I | 3 | 08-06-2006 08:03 AM |
| power loss? | drum655 | Discovery Series II | 6 | 02-23-2006 12:13 PM |
| Disco power loss | caters | Discovery Series I | 7 | 01-02-2005 06:50 AM |
