Old 01-24-2006, 09:20 AM   #16 (permalink)
yieldsign2's Avatar
Originally Posted by AdrianL
yieldsign2, not to sway from the subject but I see you don't have the A-bar or brushguard and wondering how you attached your lights?
Originally, on my old 87 rover, i just drilled holes in teh bumper and mounted them there. The problem is these lights are pretty deep.. they are hella 1000FF. The result was not really being able to aim them off the ground 2 feet in front of me, because i had to drill all the way out on teh slanted front part of teh bumper almost, for them to clear the grille. I spent a couple hours a few weeks ago fabbing up some mounts for them. They are kind of a spread "Z" shape. Basically lifts them up and out from the bumper so that they can be aimed correctly. It could use some supports welded in for rigidity, if you are off roading or hit sharp bumps on the road they vibrate a little, but regardless they aren't "legal" on the road anyway I'm pretty sure, and it's not enough to mess with your eyes, at least mine.
Pics...(i made the brackets twice. the first time was with too thin metal - way too much vibration. The thicker ones are the ones on there now.)
ok BACK TO ON TOPIC
ID:	4019  who-has-biggest-rr-classic-board-1230051730a-medium-.jpg.jpg
ID:	4020  who-has-biggest-rr-classic-board-1230051804-medium-.jpg.jpg
ID:	4021  who-has-biggest-rr-classic-board-1230051735-medium-.jpg.jpg
ID:	4022  who-has-biggest-rr-classic-board-1230051803-medium-.jpg.jpg
Devon Yablonski
1989 Range Rover Classic - Running and Muddy
1988 Range Rover Classic - Parts
http://ads.auctionads.com/pagead/lin...assZyieldsign2
yieldsign2 is offline   Reply With Quote
Old 01-24-2006, 09:32 AM   #17 (permalink)
sven's Avatar
95LWB w/ RTE 3" Lift
RTE HD Springs
RTE Pinion Corrected Front Arms
RTE Rear Links
RTE Relocated Dampner
OME Shocks (Toyota Landcruiser)
Tom Woods DC Front Driveshaft
LT230 Conversion
93 LWB Rear Ujoint Driveshaft
EE Lowered Rear Shock Mounts
Old 01-24-2006, 10:05 AM   #18 (permalink)
Default Thanks for the info
ok BACK TO ON TOPIC
Thanks alot for the info. I am going to be installing the Black Magic which is about 2" thick and I have measured the bumper and it will work without the bracket. But that is a great fab idea you have done.
Truck's looking good too!!
AdrianL is offline   Reply With Quote
Old 01-24-2006, 12:05 PM   #19 (permalink)
drg
drg's Avatar
LT230 Conversion
Very nice. Was this conversion a pain? Do you remember (and do you mind sharing) how much you had to spend in extra parts, and how many hours it took do do? Did you do the work yourself or have a shop do it?
I've got a '95 SWB and so far the BW works great, but I know some day the VC will fail and the cost to replace it will be comparable to the cost of a good used LT230, so I'm just thinkin'.
95 Classic SWB
If it's not leaking, it's empty.
drg is offline   Reply With Quote
Old 01-24-2006, 12:43 PM   #20 (permalink)
sven's Avatar
I really lucked out...I found on D90.org a complete LT230, RR linkage, and front CV style driveshaft for $450. Plus it was 50 miles from me and I was able to pick it up.
On a 95, its a nice conversion. You already have the D1 style center console, you just need the shift boot and rubber surround from a D1. Also need the window switch bezel too. I found these items on ebay super-cheap.
Your existing parking brake assembly swaps right over. You have to drill one hole if I remember correctly, no big deal.
Took about 6 hours using my friends shop and lift. The hardest part was figuring out the wiring for the shift interlock. What a PITA.
The first thing I noticed after the conversion was how easily the steering wheel turned...my VC was totally shot at 90K miles.
Old 01-24-2006, 07:31 PM   #21 (permalink)
RageRover's Avatar
Now these are some big ass Rovers with some mean ass tires! Awesome!
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 01-24-2006, 10:01 PM   #22 (permalink)
Sick Rovers Mine is one of the biggest on here all of yours looks very well done.
BIMMERBOYZ is offline   Reply With Quote
Old 01-25-2006, 12:25 AM   #23 (permalink)
drg
drg's Avatar
Wow. Just... wow.
Oh, now you're making me nervous. Mine's got exactly 100k miles on it. But, whoever owned it before was very good about maintenance, and everything works right, so I probably have some time. I don't have any binding issues, but it locks up tight when I need it. Still, it will go some day.
Thanks for the info!
95 Classic SWB
Old 01-25-2006, 06:01 PM   #24 (permalink)
100 quids for a days work son..
siam's Avatar
Originally Posted by Hank
Since Nomar is not speaking up, I'll put a pic of his truck...
Was wondering who makes the front bumper on this Rover? So all these Rovers with big tires but no specs.. comeone now people, we want to hear about the good stuff...
SupermotoUSA 917
www.DiceRacing.com
RRC beast sold
Disco 95 5 on the floor
siam is offline   Reply With Quote
Old 01-25-2006, 06:17 PM   #25 (permalink)
Rippers's Avatar
3" suspension lift
2" body lift
33" MTRs
not to bad for a 5'3" girl
who-has-biggest-rr-classic-board-articulation-alley-12-4-2005-5-small.jpg   small.jpg
1989 RRC
Rippers is offline   Reply With Quote
Old 01-25-2006, 10:21 PM   #26 (permalink)
drg
drg's Avatar
Originally Posted by Rippers
3" suspension lift
2" body lift
33" MTRs
Rippers: nice Rangie.
95 Classic SWB
Old 01-26-2006, 12:23 PM   #27 (permalink)
3" suspension lift
2" body lift
Whats the difference betrween a suspension lift and a body lift? I know, noob question
Rover Nick is offline   Reply With Quote
Old 01-26-2006, 01:09 PM   #28 (permalink)
Rocky Mountain High
Funrover's Avatar
A suspension lift - Lifets the entire truck except axles up...Larger coils, longer travel shocks etc
A body lift. - Lifts just the body of the rover higer up off the frame..suspension stays the same
Old 01-27-2006, 01:25 PM   #29 (permalink)
Rippers's Avatar
Top Picture =
Suspension lift: Big Blue 3" springs with extended bilstein shocks
Bottom Picture =
Body lift: 2" lift from Rovertym "A body lift raises the body which in no way affects driveline/pinion angles, steering geometry or trans/TC case shifting. The purpose being for using larger tires with no geometry changes and additional body clearances for obstacles." - Rovertym
who-has-biggest-rr-classic-board-dsc00169.jpg  who-has-biggest-rr-classic-board-dsc00168.jpg
1989 RRC
Old 01-27-2006, 09:55 PM   #30 (permalink)
PPR
Silver Streak's Avatar
[/IMG]
Pikes Peak Rovers
Silver Streak is offline   Reply With Quote
