So Ive done a little searching and think that I have figured out the solution. However, I figured I would run it by you guys first before I buy something.
The problem: My wipers will not go into intermediate mode. They work fine on the low and high setting but when you turn the wipers off they will not return back to thier resting position. They just stop wherever they are on the windshield. The were working great earlier this evening and when I came out from dinner they started acting up. What I think the solution is: I searched and found a guy that had a similar problem. Someone told him that it was the stop switch on his wiper motor and he would need to replace the whole unit. There was no follow up to say that this was his problem or not. So do I need to replace the entire wiper motor or what? Could it be the switch or a relay?? Any help would be appreciated. Im glad they are still somewhat working but the problem is really annoying.
Dustin 1992 Range Rover, RTE Suspension, RTE body lift, Safari Gard 3 link, GCR Wheels, Super Swampers, Warn 8000i, and more.
#2 (permalink) | |
Series Moderator
Cheers Onz
Current fleet 86 90 V8 in bits 86 RR classic Under repair 94 Disco TDI 3dr ex-police 256k and still going 80" coil sprung V8 auto Trialer in progress 71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine Stuff I have had at one time or another 76 S3 LWB 65 2a ex mil swb 71 2a swb safari 67 2a 1 tonne TACR 57 S1 V8 SWB 81 S3 SWB diesel 82 s3 SWB diesel 82 RR 2 dr perkins diesel 83 RR 4dr V8 84 RR 4dr V8 LPG 83 RR 4dr V8 LPG "in vogue" 88 RR gm 6.2 V8 Diesel 89 RR 3.5 mazda TDi 75 S3 LWB stationwagon 75 S3 2.6 LWB 86 110 2.5D 91 disco V8 91 disco TDi 89 disco V8 81 RR isuzu 2.8 TD |
I had this problem and all my research said bad wiper motor. Changed it twice with used motors that were reported to be good. Mine turned out to be the wiper relay in the dash. So I would try the relay first.... cheaper & easier, cause it's a PITA to get to the wiper motor.
Kevin 88 RRC "Audrey" |
Thanks for the replies guys.
So this morning the wipers are back to normal and are working fine. This concerns me because now I am thinking there may be a short. Water is probably getting into something causing this. I guess I will start pulling everything apart this afternoon.
