Old 02-05-2007, 06:42 PM   #16 (permalink)
sven's Avatar
Originally Posted by norville
sensor for top hose right?
bob
You'e talking about the sensor in the top radiator hose? Has 2 prongs> Thats the AC fan switch. The ECU temp sensor is in the intake manifold and the fuel temp is in the fuel rail.
99 D1
73 Series SWB
95 RRC LWB - Sold
Old 02-06-2007, 02:47 AM   #17 (permalink)
Sven, where in the intake manifold is it?
bob
norville is offline   Reply With Quote
Old 02-06-2007, 03:40 AM   #18 (permalink)
Found it.
OK now I have no leads. I will measure this sensor today. I was measuring the wrong one.
Could I have screwed things up when I set the base idle the other day?
bob
Old 02-06-2007, 03:48 AM   #19 (permalink)
Top front of the intake manifold. Behind the dissy and under the top hose.
Kevin
88 RRC "Audrey"
Old 02-06-2007, 08:42 AM   #20 (permalink)
daway's Avatar
here is a link from rr.net about the sensors
http://www.rangerovers.net/rremedies.htm#absensor
it talks about alot of differnt sensor failures
2001 X5 3.0i "dodi"
1993 RRC, county LWB "bertha"
myroverworld
Old 02-06-2007, 09:07 AM   #21 (permalink)
Both the fuel and coolant are reading 12K looking at the list that's about right. It's like 12deg here.
After it sits it almost wants to catch. I'd swear it would start, but it doesn't. Then I'll get a chug or two every few rotations. I tried a different coil wire. And checked some of the wires doming off the coil.
bob
Old 02-06-2007, 09:41 AM   #22 (permalink)
daway's Avatar
bob
do u think your starter or ign soloria (spelling?/1 of those days) is going bad. just a thought???
2001 X5 3.0i "dodi"
myroverworld
Old 02-06-2007, 11:06 AM   #23 (permalink)
Did you mess with the timing??
I still think it's the coolant temp sensor.
Kevin
88 RRC "Audrey"
Old 02-06-2007, 11:19 AM   #24 (permalink)
Kevin, timing is good I have a physical mark. pluss it was good 2 days ago.
Coolant temp sensor is reading 12k so is fuel.
bob
Old 02-06-2007, 03:06 PM   #25 (permalink)
Super Moderator
Disco's Avatar
bob
Now we're getting closer to the problem. What I suspect is happening is that your battery is not providing sufficient current to the starter to fire up the motor, probably because of the very cold temperatures you have. Put a jump start on it and I'm sure it will kick in.
Old 02-06-2007, 04:26 PM   #26 (permalink)
I tried it with the power pack. I think you close. I'm plan on throwing a blanket around the front of the rig and putting some utility lamps under there tomorrow afternoon.
bob
Old 02-07-2007, 03:58 PM   #27 (permalink)
I'm a bit embarrased.
The spark plugs were toast, even though I cleaned and dried them.
thank you all.
bob
Old 02-07-2007, 05:13 PM   #28 (permalink)
OkieRover's Avatar
Gallery: 2
All this was just some bad sparkies?
Well that's good news that it wasn't something freakin' weird.
I punch my clown daily.
Old 02-08-2007, 06:23 AM   #29 (permalink)
Elemental's Avatar
What year is your truck?
Old 02-08-2007, 06:26 AM   #30 (permalink)
91 hunter. It ran fine this morning. It still has the the poor idle in gear but I believe it's better.
bob
