Old 03-07-2007, 08:47 PM   #1 (permalink)
Default Yet Another Coolant Leak
Hi guys,
I've read a few of the coolant leak threads on here, but thought I would post anyway just to hear some replies. I bought my 3.5 liter 89 RRC back in August. Ever since purchase it has had a problem of overflowing the coolant overflow bottle once the engine gets warmed up. After awhile the coolant level gets too low and has to be replenished. The temp gauge works, and it does not overheat. I've had the cylinder compression checked twice and both times all the cylinders were ok. I also had the coolant system pressure checked about a month after purchase, and that was ok. It also seems like when the coolant does come out, it sprays out from around the cap rather than from the overflow nozzle, which is not blocked.
I'm not sure how you identify bubbles in the heater core. I went to a friend that is a bit of a mechanic and rover nut, and he said that mine was a common problem, that the overflow bottle is too small, and that most people fix it by running a hose off the nozzle from the stock overflow bottle to a second, home-installed overflow bottle.
Does anyone have any suggestions or can anyone expand on this?
drprofessional is offline   Reply With Quote
Old 03-08-2007, 05:28 AM   #2 (permalink)
Elemental's Avatar
I would look at the radiator being clogged.... Sometimes the debris bouilds up and dams inside the radiator, then when you turn the truck off, the pressure releases and begins the cycle over again...
Old 03-08-2007, 09:37 PM   #3 (permalink)
I'll check it out. Thanks.
Old 03-12-2007, 08:27 AM   #4 (permalink)
You might be lucky enough that it's just a bad cap not holding the pressure, but it might be the head gasket starting to go & pressurizing the system.
Kevin
88 RRC "Audrey"
Old 03-29-2007, 01:46 PM   #5 (permalink)
Geoffrey F Miller's Avatar
Make sure it isn't this
http://www.geoffrey-miller.demon.co....ng/coolant.htm
I hope for your sake it's not!
Geoffrey
1985 4-door Range Rover Classic
Geoffrey F Miller is offline   Reply With Quote
