Range Rover Classic Discovery I II Defender Propshaft Driveshaft Spacer - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 1 (permalink) Old 04-30-2013, 10:26 AM Thread Starter
Site Sponsor
Quoted: 0 Post(s)
British Parts of Utah gladly offers free shipping for Driveshaft Propshaft 15mm Spacer for "Land Rovers Only Members"
$45
free shipping code: LRODSFR
When suspension lift kit is fitted it increases the distance between the transfer box flange and the diff flange. This increased distance can cause the prop shaft to run out of spline travel.
Fitting this 15mm prop spacer helps return the prop shaft to its normal operating length therefore allowing full spline travel which also helps reduce the characteristic "binding" of the yokes when a prop shaft is over extended.
This kit consists of a 15mm spacer and 4 nuts and longer bolts. Machined from billit aluminium and anodised deep blue.
Fits:
94~99 Discovery I: front only, unless rear is converted to U joint
99~04 Discovery II: front only, unless rear is converted to U joint
87~94 Range Rover Classic: front & rear
1995 RRC : front only, unless rear is converted to U joint
95~02 Range Rover 4.0/4.6: front & rear
94~97 Defender 90: front & rear
93 Defender 110: front only
Land Range Rover Discovery Defender Factory Genuine Aftermarket Driveshaft Drive Prop Shaft Spacer
bpUtah is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Supporting Vendors > British Parts of Utah
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
removing front driveshaft/propshaft wt26 Discovery Series II 11 11-30-2012 11:01 PM
FS: Land Rover Discovery I, Range Rover Classic, Defender custom HD Radius Arms BlackListedRovers Land Rover Parts and Accessories 2 10-23-2012 08:45 PM
Propshaft spacer? philippe Range Rover Classic 2 12-23-2008 07:58 AM
Discovery/Defender/Range Rover parts wookie110 Land Rover Parts and Accessories 20 02-09-2006 08:51 AM
RamAir Air Filter for Land Rover Discovery 1 95 Range Rover Classic $25.00 hamrendan Land Rover Parts and Accessories 0 01-24-2005 08:08 AM
You may post new threads
You may post replies
