Old 09-01-2004, 02:03 PM   #1 (permalink)
Default 100000 miles
Just about to buy a 1996 300tdi with two owners and 100000 miles on clock,
looks very tidy good spec (air con autobox) up for £6500 anybody give me any pointers on what to watch out for apart from the norm!
Andrew1002 is offline   Reply With Quote
Old 09-01-2004, 03:49 PM   #2 (permalink)
rbr
Leaks and rust.
Fold down the back seats, lift the carpet and look at the boot floor. I'd bet that the insulation will be soaking, and the floor very rusty.
The good thing for the buyer is that this looks really scary, but is very easy to fix. You might get away with wire brushing then coating with Hammerite, but even if it's completely rusted away, a replacement floor panel costs about 60 quid. The water is almost certainly coming in thru the sunroof or the gutter join.
But it looks scary, so is a very good negotiating point when haggling over price!
Also, check when the timing belt was last done, and whether the timing mod kit has been fitted. A blob of yellow paint on the timing cover usually, but not always, means the modified kit has been fitted.
Bruce.
rbr is offline   Reply With Quote
Old 09-02-2004, 10:29 AM   #3 (permalink)
Just as Bruce says , but drying the insulation out is a long drawn out affair .
Proffesional Gypsy & mate of Stig of the Dump
Backstaber_1 is offline   Reply With Quote
Old 09-04-2004, 01:35 PM   #4 (permalink)
Most important of all make sure gearbox does what is meant to!
They all clunk as you move from drive to reverse and back again if you hold foot on brake this is much reduced, but obviously forget to mention this and you have a bargaining point.
Make sure cruise works.
Lynall
lynall is offline   Reply With Quote
