Old 07-18-2008, 12:46 PM   #1 (permalink)
Kaz
Default 16" rims from D1 2001
would they fit my D1 ''''95
and if they fit - they are 255/70/16, I have 235/70/16 on the trk now- would that pose a problem?
I guess not, the difference would be 14mm in height, if my calculations are correct..
Kaz is offline   Reply With Quote
Old 07-18-2008, 02:05 PM   #2 (permalink)
antichrist's Avatar
D1 wheels are interchangeable between years of D1's, but not with any DII's.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 07-18-2008, 03:13 PM   #3 (permalink)
Rebuilding Rover
ArmyRover's Avatar
and a 2001 Disco would be a Disco II
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 07-19-2008, 06:14 AM   #4 (permalink)
antichrist's Avatar
Well..I wasn't really sure what he was asking, since the question was about wheels, and then he was giving tire sizes.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 07-19-2008, 12:49 PM   #5 (permalink)
its not that hard to understand him. If the wheels are from a d2 they will not fit due to bolt pattern. The tires will fit on your old rims though and you should be fine clearance wise.
amschnellsten is offline   Reply With Quote
Old 07-19-2008, 01:27 PM   #6 (permalink)
Rebuilding Rover
ArmyRover's Avatar
oh and the 255/70 will rub a bit on tight turns.
http://snhlr.org/
90 RRC Parts truck
Old 07-20-2008, 05:56 PM   #7 (permalink)
Kaz
will they really, or you're pulling my leg?
The difference in hight is 14mm..
By how much I can safely increase the tire hight on a stock car?(D1)
Old 07-20-2008, 05:58 PM   #8 (permalink)
Kaz
of course, my bad..
Old 07-25-2008, 07:17 AM   #9 (permalink)
on, off, on, off, on...
Capt. Ron's Avatar
I have this size, 255/70 16 A/T, on my DI with no rubbing.
The difference in size, from the 235/70 to the 255/70 is 6-15/32 to 7-1/32 which is 9/16 or 14.2mm approx.
03 Disco w/CDL
95 Disco
98 Disco: my first (gone)
Capt. Ron is offline   Reply With Quote
Old 07-25-2008, 07:41 AM   #10 (permalink)
Rebuilding Rover
ArmyRover's Avatar
I found that I would get minimal rubbing on the radius arm with the 255/70 on a RRC so I'm sorry to say I assumed that would be the case with the DI as well.
http://snhlr.org/
90 RRC Parts truck
Old 07-27-2008, 06:06 PM   #11 (permalink)
Kaz
thanks for responding and clarifying.
Old 07-27-2008, 06:17 PM   #12 (permalink)
Kaz
sorry , a repeat..
Old 07-27-2008, 06:36 PM   #13 (permalink)
Rebuilding Rover
ArmyRover's Avatar
I need to correct myself I noticed that my old tires were 265/70 so the 255 are probably good to go
http://snhlr.org/
90 RRC Parts truck
Cost for 16" Rims Danger Wheels and Tires 13 03-22-2008 07:49 PM
Dii 16" Oem Rims stb616 Land Rover Parts and Accessories 0 02-21-2008 07:09 AM
FS: 16" OEM Wheels from 2001 Rang Rover rcristobal Land Rover Parts and Accessories 0 11-22-2006 01:06 PM
Trade 16" Disco II rims for 18" ? TsiArt Land Rover Parts and Accessories 3 08-23-2006 12:46 PM
Looking for 16" rims for Disco II in Sacramento, CA Area xtreme90 Land Rover Parts and Vehicles Wanted 3 01-12-2005 12:52 PM
