1995 Discovery 1- passenger side cylinders not firing - Land Rover Forums : Land Rover and Range Rover Forum
 1Likes
  • 1 Post By peter r
post #1 of 6 (permalink) Old 02-26-2017, 03:35 PM Thread Starter
Quoted: 0 Post(s)
Exclamation 1995 Discovery 1- passenger side cylinders not firing
I have a 1995 Disco 1 with rebuilt motor-heads replacement etc. Vehicle cranks up with very rough idle, running only on 4 cylinders drivers side. Just installed new fuel injectors, power to injectors seems to be good from wiring harness, 32 -34 psi on fuel rail, spark from new wires and plugs but fuel injectors seem to not be receiving signal to distribute fuel. My guess anyway. Any ideas on problem? Could it be bad ECU? If the ECU is bad will it still run on 4 cylinders? Any help would be greatly appreciated.
Thanks
Mid Florida Disco 1 is offline
post #2 of 6 (permalink) Old 03-03-2017, 10:50 AM
Quoted: 2 Post(s)
1995 should be a distributor engine. I'd look there for your lack of spark.
fishEH is offline
post #3 of 6 (permalink) Old 03-04-2017, 01:12 PM
Special Agent
redtruck12's Avatar
Quoted: 121 Post(s)
Garage
Sounds like injector control the way I read it.
How did it run before the engine work?
Happy Happy Happy
2004 D2 se5 (sold)
2001 D2 se5 (parts truck)
2000 D2 se7 (retired)
1997 D1 (sold)
redtruck12 is offline
post #4 of 6 (permalink) Old 03-04-2017, 03:41 PM
Ian Matthews
p76rangie's Avatar
Quoted: 161 Post(s)
Yes, one bank's injectors fire at the same time and on a single circuit. So it is possible that there is something wrong with that circuit that is stopping a whole bank from firing.
p76rangie is offline
post #5 of 6 (permalink) Old 03-26-2017, 02:03 PM
Quoted: 0 Post(s)
Not sure if this makes sense, but mine was doing the exact same thing. I bought it cheap from a guy who thought the engine was blown. Found a coil behind the engine, replaced it and runs perfectly.
Dave Peterson is offline
post #6 of 6 (permalink) Old 04-04-2017, 03:54 AM
Quoted: 3 Post(s)
G`day ,
I didn`t read the heading you do say pass side , so you`ll look at pin 11 YW .
The ECU uses pin 11 AND pin 13 to alternately earth each bank .
Pin 11 uses YW yellow/white to earth cylinders 2 , 4 , 6 and 8.
Pin 13 uses YU yellow/blue to earth cylinders 1 , 3 , 5 and 7 .
The main relay , pin 87 power all the injectors via NO brown/orange .
If it runs on one bank you`ll have power to all eight injectors because it uses one wire the NO .
You should be able to check the continuity of the YW and YU wires by un pluging the ECU and check that the ECU pins 11 and 13 are earthing .
redtruck12 likes this.
PLR elsewhere
84/5 RR 4.0ltr Torqueflite Standard
93/4 RR 3.9ltr ZF Hard dash Vouge SE
94/5 RR 4.6ltr ZF Soft Dash Vouge SE
03/4 RR 3.0ltr TD6 GM HSE
peter r is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
1995 RRLWB Passenger side lights Jason Durant Walker Range Rover Classic 1 02-06-2017 03:30 PM
96 disco 1 not firing on all 8 cylinders all the time DiscoChris10 Discovery Series I 4 08-28-2012 04:05 PM
Discovery 1 02 Sensor plug - Red on Passenger Side? pbsled Discovery Series I 5 12-15-2010 03:19 PM
multiple misfires again... 4 "passenger side" cylinders misfiring prettynpink1029 Discovery Series II 27 02-11-2009 06:12 AM
Discovery 1 passenger side running board/side step roverpwr Land Rover Parts and Vehicles Wanted 12 04-09-2007 06:20 PM
You may post new threads
You may post replies
