The Urban Motorist
![]() Join Date: Sep 2004
Hi there from Adam in NYC
Just had the crankshaft sensor go bad, and had it replaced. Now when I engage the cruise control on the highway, it won't work. Anybody have a quick way to troubleshoot the cruise control? |
A real Hillbilly from KY.
Look under the hood on the drivers side, you'll find a plastic "tee" close to the fender between the firewall and the wheel well. If only one or two vacuum lines are plugged into it, that's the problem. there should be three
lines connected to the "tee". If all three lines are plugged in, most likely you'll wanna' check closely and see if the lines are cracked. if they are, trim them up and re-plug 'em in.
DRAGUNOV -------> Don't run from me... You'll just die tired. '99 Discovery II '98 Discovery I '89 RRC "The Lizard" RoverAddiction
The Urban Motorist
The posts have been sluggish because of the holidays, and I am poring over the Haynes manual without much success. Still can't find the fuse(s) for the cruise control and the cold snap this winter makes working on a streetparked D1 painful to say the least.
I will let you what is the problem when it warms up here in Brooklyn NY.
-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=--=-==-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Owner of a 1996 Land Rover Discovery 1 in Beluga Black or the Dirt of the Day. Where we are going,we don't need roads. Nothing in education is so astonishing as the amount of ignorance it accumulates in the form of inert facts. ‘The Education of Henry Adams’ (1907) ch. 25 |
Does your horn work?
If i remember from troubleshooting mine the horn fuze and CC fuze are the same. Track down the vacuum lines like Dragunov said. They have a tendency to crack badly too. If all that fails, it could be either your pump or the ECU for your CC. You can test the pump easily, but i dont know about the ECU.
![]() ![]() 77 SIII 88 97 D1 5 speed 91 D1 5 speed (the first, but gone )When god gives you lemons, find a new god.... |
| Thread Tools | |
| Display Modes | |
| Cruise Control Help | Disco Truck | Discovery Series I | 6 | 03-26-2007 10:16 PM |
| Cruise control - slowly stopped working | NiagaraRover | Discovery Series II | 4 | 08-01-2006 10:42 AM |
| Surging with Cruise Control On | hermanpj | Discovery Series II | 5 | 01-22-2005 10:17 PM |
| Cruise control on manual TD5 2004 | dfe | Discovery Series II | 4 | 01-19-2005 04:05 PM |
| Cruise Control Does Not Work After Warm Up | S Couch | Discovery Series I | 2 | 09-26-2004 09:36 AM |
