Old 12-11-2007, 09:08 PM   #1 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Question 1996 D1 Cruise Control not working- any ideas how to fix?
Hi there from Adam in NYC
Just had the crankshaft sensor go bad, and had it replaced. Now when I engage the cruise control on the highway, it won't work. Anybody have a quick way to troubleshoot the cruise control?
Old 12-13-2007, 05:00 PM   #2 (permalink)
Sounds like a vacuum line got pulled loose.
bruce441 is offline   Reply With Quote
Old 12-13-2007, 10:48 PM   #3 (permalink)
A real Hillbilly from KY.
Dragunov's Avatar
Look under the hood on the drivers side, you'll find a plastic "tee" close to the fender between the firewall and the wheel well. If only one or two vacuum lines are plugged into it, that's the problem. there should be three
lines connected to the "tee". If all three lines are plugged in, most likely you'll wanna' check closely and see if the lines are cracked. if they are, trim them up and re-plug 'em in.
DRAGUNOV -------> Don't run from me... You'll just die tired.
'99 Discovery II
'98 Discovery I
'89 RRC "The Lizard"
RoverAddiction
Dragunov is offline   Reply With Quote
Old 12-20-2007, 08:46 PM   #4 (permalink)
The Urban Motorist
Thumbs up Thanks Guys, you are the Greatest!
The posts have been sluggish because of the holidays, and I am poring over the Haynes manual without much success. Still can't find the fuse(s) for the cruise control and the cold snap this winter makes working on a streetparked D1 painful to say the least.
I will let you what is the problem when it warms up here in Brooklyn NY.
inert facts.
Old 12-21-2007, 06:18 AM   #5 (permalink)
msggunny's Avatar
Gallery: 5
Does your horn work?
If i remember from troubleshooting mine the horn fuze and CC fuze are the same.
Track down the vacuum lines like Dragunov said. They have a tendency to crack badly too.
If all that fails, it could be either your pump or the ECU for your CC.
You can test the pump easily, but i dont know about the ECU.
77 SIII 88
97 D1 5 speed
91 D1 5 speed (the first, but gone )
When god gives you lemons, find a new god....
msggunny is offline   Reply With Quote
Cruise Control Help Disco Truck Discovery Series I 6 03-26-2007 10:16 PM
Cruise control - slowly stopped working NiagaraRover Discovery Series II 4 08-01-2006 10:42 AM
Surging with Cruise Control On hermanpj Discovery Series II 5 01-22-2005 10:17 PM
Cruise control on manual TD5 2004 dfe Discovery Series II 4 01-19-2005 04:05 PM
Cruise Control Does Not Work After Warm Up S Couch Discovery Series I 2 09-26-2004 09:36 AM
