Links
Old 04-27-2008, 03:39 PM   #1 (permalink)
Default 1996 Disco check engine light
I bought a 1996 Disco yesterday, and it was running great on the way home, and most of the day. It started having a little flutter sometimes, not always, while at a stop light. Well I took it to the store, and when I came out and went to start it, it was hard to start, and would die if I let off the gas, I drove it back home and adjusted the idle up, and it does not die now, but the check engine light is on. Also I wanted to clean the battery terminals, and disconnected the battery and the radio now wants a code to work. The company I bought it from has no clue what the code is, and I called LandRover and they gave me a code but it did not work, any clues?
biggdoggs1 is offline   Reply With Quote
Old 04-27-2008, 06:10 PM   #2 (permalink)
Shaymer's Avatar
Um... I had the same problem with my 96 Disco. The place I bought it from had do idea what the code is, so I ended up going to Circuit City and getting a new radio. The factory radio had a cassette player, so its not like it wasn't do for an upgrade anyway.
I'm looking at my factory stereo that I just had yanked out of my vehicle. There isn't a code anywhere on it, BUT Circuit City said that they could reset or check it for $50 bucks, so I'd let them call the company and try to figure it out and if they don't, well, don't pay them.
Shaymer is offline   Reply With Quote
Old 04-27-2008, 07:56 PM   #3 (permalink)
discowilson's Avatar
do you have your manual? in the manual it tells you how to reset your code? if you want ill check my disco manual tomorrow and let you know
1996 D1 SE7
discowilson is offline   Reply With Quote
Old 04-27-2008, 08:36 PM   #4 (permalink)
No, it did not come the owners manual. Thanks any info would be great! I do plan on ordering one.
Old 05-02-2008, 08:13 AM   #5 (permalink)
mikebtvs's Avatar
Default I've got the code at home
I've got a '96 disco also, and I have the code at home, I'll get it for you later when I get home
mikebtvs is offline   Reply With Quote
Old 05-02-2008, 08:21 AM   #6 (permalink)
Elemental's Avatar
You adjusted the idle? Why? If it worked fine before, and didnt work all of a sudden, do you think it COULD be a part failure,not a adjsutment? I bet your check engine light is on. The computer is confused.
You can backyard Bob the adjustment after you correct the failed part. But, your computer has a small window of what it calls acceptable.
The only way to accurately adjust base idle on gems engine is with a Testbook.
Radio Code.... Each radio has a different code. Did you pull it out and give the dealer your Serial Number? They CAN look it up from that.
Old 05-03-2008, 05:53 AM   #7 (permalink)
kiamichi's Avatar
I had to prove to the dealer that I was the owner and they provided me with the radio code and it worked. I did pull a Car Fax report for $30.00 before I bought it and knew what dealer had been used in it's life. It's a good report to have if you want a history of your car. I now have have 2 '96 Discos, but will sell one later.
kiamichi is offline   Reply With Quote
Old 05-03-2008, 02:42 PM   #8 (permalink)
five bucks says the pcv hoses are torn and the belt is installed incorrectly causing alot of his issues.
Old 05-04-2008, 10:35 PM   #9 (permalink)
Support Our Troops
apbtpetey's Avatar
As for the radio code not working, somebody more then likely tried to enter the code in to many times. It only allows you to try a few times before locking up. The code you got from LR should be correct, but if I remember right you have to leave your key in the 2nd position for something like 30 mins to rest the system and then you can enter the correct code into the radio. Atleast that is what I had to do for the radio to work in my 97 Disco.
John Conklin
LRO Moderator
apbtpetey is offline   Reply With Quote
Comments/Suggestions [Post Here] rmuller Tech & DIY 29 04-20-2007 06:33 PM
e-brake nd check engine light floridadiscoI Discovery Series I 1 04-14-2007 04:42 AM
'96 Disco with Check Engine... discoverychannel Discovery Series I 3 01-08-2007 11:57 AM
Check Engine Light, No Code on Display OkieRover Range Rover Classic 5 10-24-2005 07:37 PM
Check Engine Light scott Discovery Series II 2 09-01-2004 08:01 PM
