Old 10-27-2007, 02:05 AM   #1 (permalink)
Default 1996 Land Rover Discovery Transmission and ABS Light and Window
I just bought a 1996 Land Rover Discovery Automatic Transmission and 88k miles and I have 3 current problems I need to address.
#1 The ABS Light is On. How can I trouble shoot this?
#2 The passenger side window only goes down a few inches and gets stuck. But goes back up fine.
#3 After i lift my foot off of accelerator the vehicle jerks once or twice and then runs ok at any speeds
umoms is offline   Reply With Quote
Old 10-27-2007, 09:00 AM   #2 (permalink)
1, You really can't trouble shoot this, need a mechanic with a good scanner.
2, Sounds like a broken window regulator, pretty common problem.
3, As I mention to you on your other post, go see a tranny shop, see what they suggest, might try checking your fluid level and changing you ATF.
