» Sponsors
» Sponsors
Old 11-04-2009, 09:09 AM   #1 (permalink)
Question 1999 sd discovery high rpms.
good day all
got a question, my discovery one sd series runs at high rpms
even after its warm up. i pulled the idle air control valve and cleaned
it out. ,i sprayed the engine front area around the fan let it set
just a few minutes then rinsed. waited for the engine to dry. now it runs
around 1500 rpms. any suggestions would be great. i have the rave cd
and i considered my self a fair mechanic. when i was in the army i worked
12 cylinder air cooled twin super charged diesl engines.
thanks/valkrie
valkrie is offline   Reply With Quote
Old 11-04-2009, 12:40 PM   #2 (permalink)
Did this start before or after you cleaned the IAC?
osiristheclown is offline   Reply With Quote
Old 11-07-2009, 07:19 AM   #3 (permalink)
Default valkrie
no after i cleaned around the front end ofthe engine. the other day i drove it to my doctor appointment and on my return the idle went down to under a thousand rpm's. i removed the idle air control vavle, i saw no serverable parts. i wiped both surfaces clean and reattached. still runs high but sometimes it will the rpm's will go up then idle down, still between thousand and fifthteen hundred.
thank, buck
Old 11-07-2009, 11:54 AM   #4 (permalink)
Check your coolant temp sensor, the one for the ECU. It's on the front of the manifold, maybe you got the connection wet while hosing off the engine or the sensor is just bad. The sensor tells the ECU the engine temp and has a 2 wire connector like the ones on the fuel injectors. Don't confuse the sensor with the coolant temp sender that operates the gauge in the dash, 2 different parts with 2 different functions.
Old 11-07-2009, 06:12 PM   #5 (permalink)
Cool valkrie
thanks for the info. I pulled the wrong part and was confused as to which was which. I finally puled the right one and boy was it carboned up. I cleaned off all the carbon i could with solvent, but had to resort to my dremmel tool. finished cleaning with the dremmel and also cleaned the port where it goes. cranked the engine and ran like new.
Thanks again for the info if you need anything i have been doing alot of research and have alot of info will be glad to share.
1999 Discovery ~ D1 or D2 MileHighRover Discovery Series II 2 08-19-2009 02:47 PM
2002 Discovery Parts and Hannibal Equipment for sale nathansharkey Land Rover Parts and Accessories 11 02-06-2009 02:51 PM
Safety Devices Discovery Series I Highlander High Roof Rack John Bulik Land Rover Parts and Accessories 9 02-01-2009 07:14 PM
Question about 1999 Discovery creorange Discovery Series II 5 05-14-2008 12:07 PM
1999 Discovery Light bulb guide darkknight1999 Accessories 3 03-22-2006 10:31 AM
