Old 08-30-2004, 01:18 AM   #1 (permalink)
Question 200Tdi drinking water
Dear all fellow Disco and LR owners,
I got a 1993 200Tdi, who has started to use water. I dread expensive problems.
I have not been succesfull in finding the source of the leak, but I did notice water driping last time I lifted the vehicul (got a friend with a garage...a must when it comes to old LRs ) The dripping came from the back of the engine, on the right side, and it seems to apear at the top of the engine. However, I am quite sertain there is no water inside that part of the engine, so I consider the source to be further to the front of the engine (possible around the termostat housing), and that the air flow has pushed the water all the way back.
I belive to fill a litre of water every couple of houndreds KM.
Any suggestions of where to search, or even how to search?
Thanks
Kai
Just got myself a Hannibal 1.4 Rooftent!!!!
1993 Disco 200Tdi
roer.com is offline   Reply With Quote
Old 08-30-2004, 04:45 AM   #2 (permalink)
SimonArmstrong's Avatar
Lightbulb
That water could be just a coincidence, and the headgasket could have blown. Is there any mixing of water/ oil, and is there any steam from the exhaust?
Im not sure of the layout on these vehicles, but could it be a leaking heater matrix pipe?
HTH
1975 LWB S3 - Hybrid project sorta thing
1992 RR Vm Nightmare!!
SimonArmstrong is offline   Reply With Quote
Old 08-30-2004, 08:55 AM   #3 (permalink)
Get someone to pressure test the cooling system this should take about 1 hour.
Lynall
lynall is offline   Reply With Quote
Old 08-30-2004, 09:09 AM   #4 (permalink)
Takes more like 5 minutes, ive done it several times. But you will still get charged for the hours labour!
Old 08-30-2004, 12:07 PM   #5 (permalink)
Only water and the coolant is leaking - no oil. Cannot find any steams neither.
I will try to pressurise the system - however - what would that do for me? Is it likely to show where the leak is?
Thanks for your answeres and help!
1993 Disco 200Tdi
Old 08-30-2004, 04:17 PM   #6 (permalink)
Default Water leak?
Hi Roer,
Is the water coming from anywhere near one of the core plugs? Just a thought but you never know.
Bryan
'94 300 tdi Discovery
'90 200 tdi 90
bryan90 is offline   Reply With Quote
Old 09-01-2004, 01:58 PM   #7 (permalink)
Hi Brian,
what is a core plug (sorry, lack of english knowlegde)?
And most importantly - where on the engine is it located?
Br,
Kai
1993 Disco 200Tdi
Old 09-01-2004, 03:01 PM   #8 (permalink)
Wink core plug
The core plugs (sometimes called frost plugs or expansion plugs) are the circular depressions on the sides of the cylinder block. I am not sure of the exact location on the 200tdi but I will check tomorrow and post again.
Bryan
'90 200 tdi 90
Old 09-02-2004, 04:00 AM   #9 (permalink)
Default Leaking Disco
Common fault, has happened to mine twice, and is currently leaking. Its' one of the rubber hoses going to the heater. It's perished.
dakeb is offline   Reply With Quote
Old 09-04-2004, 03:12 AM   #10 (permalink)
ok, thanks all
I will check the plugs - after a cleaning of the engine.
Will also check all hoses!
kai
1993 Disco 200Tdi
Old 09-06-2004, 06:42 AM   #11 (permalink)
Default leak found
Hi again,
sorry for my slow replys...
At last - after an engine clean, it seems like the water is leaking from where one of the fuel injectors (the one closest to the cabin/back of the vehicule) is connected to the engine.
The leak only occures when the cooling system is presurized (makes sense, probably).
It seems like the water is comming from where the injector is pushed into the engine block.
Any ideas what causes this, and most importantly - how to fix it?
Thanks all!
Kai
1993 Disco 200Tdi
