Old 09-25-2005, 03:28 PM   #1 (permalink)
Default 3rd Brake light wont work
Hey all,
I was following my wife home and noticed our 3rd brake light isnt working,
So I checked bulb and changed it Didnt help so I took the other cover off and check connections and wires all seems ok Any ideas what could be causing this let me know
Thanks Eric
95 Disco
undefinedundefined
GentrysRover is offline   Reply With Quote
Old 10-04-2005, 03:05 PM   #2 (permalink)
More than likely the cable in the rubber between the door and the body work broken after work hardening - bit of a pain to change I'm afraid.
buster999 is offline   Reply With Quote
Old 10-19-2005, 08:31 PM   #3 (permalink)
LRDMICHELE's Avatar
I had the same problem with my brake lights. They were intermittent and they'd work if I jiggled them, then stop working again. I spoke to the dealer about it, and they said that the bulb case gets hot, melts a bit and then somehow causes a bad connection, and recommended replacing the whole light kit. I bought two light kits from British Atlantic for $38.00 each, and my husband installed both of them within an hour. The kits came with all of the bulbs too-it was the cheapest, quickest fix I've ever had! I haven't had any problems since, and they had been a thorn in my side for years! It's worth it to just get new light kits. It must be a common problem, because I've seen about 5 Land Rovers driving down the road with only one brake light.
I have a Disco 1 1997, only 48,000 miles on it. Take care, Michele
LRDMICHELE is offline   Reply With Quote
