Links
Old 08-23-2004, 07:48 AM   #1 (permalink)
Default £ 6225 repair quote!!! - Help!
Hello, I have logged onto the forum to see if anyone has any ideas for a cheaper option for repairing my front axel.
I found an oil leak, which has been caused by a split running from the diff right along the axel case - just under the weld, to the end of the axel. This crack is about 450 mm long!. Nobody who has looked at it seems to have any ideasother than the local land rover dealer - who have quoted me £ 6225. I have been advised not to drive it far, and live in Cambridge UK.
Thanks.
Aldarion is offline   Reply With Quote
Old 08-23-2004, 08:28 AM   #2 (permalink)
LRO Founder
Serg's Avatar
So you are being quoted $10k US to replace the front axle???? Sounds way WAY too high!
Serg
Current Vehicles:
1995 Range Rover Classic LWB in Beluga Black
2005 BMW R1200GS
2004 Element Skateboard (Indy trucks, Bones Swiss, etc...)
Past LR's:
1995 Range Rover LWB Classic
1997 Discovery XD
1995 Range Rover LWB Classic 4.0
Serg is offline   Reply With Quote
Old 08-23-2004, 09:18 AM   #3 (permalink)
Default Cracked axle housing
Serg
How about having the axle degreased and let a good welding shop weld the crack? I believe it can be welded and reinforced pretty easily.
Mike J.
Old 08-23-2004, 11:22 AM   #4 (permalink)
Default How much ! ! !
Hi,
Wow !
What model/year Disco do you have ?
£6225 ? even if the axle was unrepairable that seems a kind of high quote
Jim
Probably the best looking bloke you'll ever meet.
brummiejim is offline   Reply With Quote
Old 08-23-2004, 01:22 PM   #5 (permalink)
Serg
Exactly my feelings, remeber this is a LR main dealer with main dealer labour costs.
Old 08-23-2004, 01:26 PM   #6 (permalink)
Mike J.
Thanks, this is something I have thought about, but not knowing too much about welding was unsure how effective it would be.
Old 08-23-2004, 01:34 PM   #7 (permalink)
Originally Posted by brummiejim
Hi,
Wow !
Jim
1996 P 300 TDI
The quote is for a whole new front axel assy. I think LR imagine there is damage to the axel as well as the cover!
Old 08-23-2004, 11:49 PM   #8 (permalink)
Exclamation Ahhhhhhhh
Hi,
I would change the axle case.
If the axle is actually damaged then you could try places like equicar ? and the salvage merchants in the monthly Landy mags.
I've even seen axles for sale on Ebay at good prices.
Depends what work you would take on
Try a Landy garage thats not a dealer they'll probably sort things out a lot cheaper than 6K
Good luck
Jim
Old 08-24-2004, 04:50 PM   #9 (permalink)
Default How Much!!!???
£6k + for an axle is quite absurd. I would suggest that you buy a copy of one of the several excellent Land Rover specialist magazines and peruse the adverts. Land Rover Owner International, Land Rover World and Land Rover Enthusiast are all avaialable at high street newsagents.
The quote you have received is almost more than the car is worth. I beleive tha the axles are cast, so welding can be tricky. You would probably be better off getting a whole replacement unit from a breaker.
Changing the front axle is not as daunting as you might at first assume. You will need a ball joint splitter and perhaps a 4" angle grinder if the radius arm bolts have corroded onto the bush sleeves.
Support the chassis on axle stands, unbolt everything with the wheels on and roll it away. Swap the wheels and roll the new on into place. I would also suggest investing in Haynes Manual 3016 which covers the Disco 200 & 300 Tdi. Even if yours is a V8, this will not affect the undercarriage.
Kevanch is offline   Reply With Quote
Old 08-24-2004, 05:20 PM   #10 (permalink)
Default Leaking Axle Housing
I would still suggest that you not try to stimulate the economy all by your self. Why buy a new axle housing assembly when you can have it welded. Welding is part of how they are made in the first place and I have been in a number of shops where they cut or add to the housing all the time by welding.
Mike J.
Old 08-24-2004, 05:59 PM   #11 (permalink)
130CC's Avatar
Default Welding
It is possible to weld axel casing an is often done on competition trucks to add strength. I would ensure that the person doing the repairwork has done similar repairs or gusseting work previously as to much uneven heat can warp the axel housing. And here I was thinking that landrover parts are expensive here in Aus.
Old 08-25-2004, 02:59 PM   #12 (permalink)
Default Replacing axle casing
I once bought a complete 24 spline front axle for 150 GBP, with halfshafts, diff and hubs complete from a breaker.
When you decide to clean and paint the axle, replace all seals and inspect bearings and replace if necessary , it will be a lot less than 6000 quid !!!
2004 TD5 Disco II
1985 RRC V8 3.9 Edelbrocked also named "The mud eating monster"
1998 Defender 110 300 Tdi
1987 RRC V8 3.5 i
kristof is offline   Reply With Quote
Old 08-25-2004, 05:38 PM   #13 (permalink)
I dont think 300 series are uncommon now to breakers although I think the 200 could well be the same , there are a couple of breakers on the web all depending where you are try these for starters ,
http://www.4x4web.co.uk/links.html#breakers
I am pretty certain you could get a secondhand one and have it fitted for way less than you have been quoted .
PS: you havent been quoted for a gold plated one have you :p ?
seamus is offline   Reply With Quote
Old 08-31-2004, 01:29 PM   #14 (permalink)
Thanks for all of your ideas and advice, I have had a new axle case supplied and fitted for 580 pounds by a local independant LR garage.
thanks again.
Old 09-01-2004, 04:09 AM   #15 (permalink)
Default £6225?
You can buy my entire Disco for under £2000!
dakeb is offline   Reply With Quote
Old 09-01-2004, 01:00 PM   #16 (permalink)
lrmaniac's Avatar
£6225 for a front axle assembly?
Not even here in Portugal we get robbed like that!
now that's a nice buy!
Thank you
Joao Pedro
Defender 90 Td5; 1966 88"SIIA
lrmaniac is offline   Reply With Quote
