Old 05-03-2005, 07:08 AM   #16 (permalink)
4x4 Adventure Gear
John C's Avatar
Originally Posted by cdr146
Having tires rotated and balanced as well as alignment checked. Tires are new Michelin, only about 10k miles on them so I'm pretty sure it is a suspension issue. After reading posts here and looking through the Haynes repair manual, I believe it is the Panhard Rod, either the bushings need replaced, or the bolts have started to rub the mounting bracket. I will know tomorrow for sure, thanks for everybodys help in the diagnosing.
I don't think it's the panhard rod but if you want to check it yourself you can do the following:
Have someone start the engine and move the steering wheel from left to right (about a 1/4 turn or less). Look at the panhard rod, if it has some play in it then replace the bushings and the bolts. It's very important that you replace the bolts also since the get pitted and contribute to the play.
Good luck.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
