Old 03-14-2005, 07:23 AM   #1 (permalink)
Default 95 disco angled rear drive shaft
Hey y'all
On the 95 disco it has the angled rear drive shaft with the dumb rubber coupling.. Annoying .. There has got to be a way to put a standard u joint with out buying the whole shaft 399.99 I know u can replace the rubber coupling but how long will it last again till vibration starts let me know if you guys have been able to add a ujoint with out whole shaft.
thanks Eric
undefinedundefined
GentrysRover is offline   Reply With Quote
Old 03-14-2005, 12:42 PM   #2 (permalink)
beer drinking member
dent's Avatar
aahhh the stupid rubber problem.. had the same problem. i just replaced mine but was looking into alternatives. find a used drive shaft for about 150.00 from a newer model disco don't know if the d2's will work though. get a 4 bolt flange for about 100.00 and swap it out. i personally got lazy and opted to just change the coupler.
you're going to need a slid hammer to get the central pin out though which can be a pain
take care
sam
oh and that coupler ought to last you a long time. asked some mechanics as to why the hell LR would put a stupid peice of rubber. explaination was the there's already alot of drive clunk with the coupler, would be worse with u joint. sounds fair to me. know a few ppl that did the conversion and they said the clucking isn't too bad but can see how it'll anony some people
dent is offline   Reply With Quote
Old 03-14-2005, 12:52 PM   #3 (permalink)
yeh same here, i just opted out and got a standard rubber one for 70 bucks...
rov'n is offline   Reply With Quote
Old 03-15-2005, 09:18 PM   #4 (permalink)
I have heard that you can use a drive shaft from a 88 - 89 Rangie, just make sure that you get the pinion flange with it. There should be an old RR in a salvage yard somewhere. If you plan on lifting the Rover in the future the drive shaft will be required as the roto-flex wont take much lift. I bought the driveshaft conversion years ago, when it was only 299.00. You may still find it for less @ dap-inc.com, great place for parts. Good Luck! LRW
LRWheelman is offline   Reply With Quote
Old 03-16-2005, 06:50 PM   #5 (permalink)
Make sure the spline count on the flange mates to the pinion on your rig. The 10 spline rigs used a different flange spline count.
Removing the centering peg isn't that big a deal. Use a bolt down the center and a big socket as a puller. I was amazed at how easy it was after hearing all the stories of doom and impending doom when undertaking this task.
Also, make sure the flange you get doesn't need a spacer ring. Some flanges have a longer casting that doesn't use the spacer.
Peace,
PT
PTSchram is offline   Reply With Quote
