I have a 95 disco 3.9. I live in colorado and it was the coldest night my disco has ever seen. It was runnning fine yesterday but this morning it wouldn't start. I jumped it and it started for a moment then died. This problem repeated and when it did run it sputtered and died. On the first crank it sounds normal, goes to normal idle, but then dies. I put heet in the gas and even put octane boost via rovers north advice. still will not run. Any advice? Fuel pump? fuse? relay? thanks crowbar
this link
http://www.roverparts.com/Tech_Hard_...d_weather.html has this bit of advice There is a service bulletin circulating at the Range Rover Dealers that you should know about. It suggests that you consider placing 5W-40W oil in your vehicle if you live in a cold climate. This will allow the starter to turn faster and help eliminate flooding problems in cold start situations. Move back to a 10W-40or 20W-50 in warmer climates and in the summer. hope it helps tonka_thom ![]() |
Thanks tom
That is my next on the to do list I think my fuel pump is the culprit but it is -2 today so I have to wait till it warms alittle to get out and check all fuses and relays. Do you know were the fuel relay is on the 95 disco? Also I found a pump and all hardware and shipping for around $215 Any thing you have found cheaper? Thanks Crowbar |
