Old 05-31-2007, 12:40 AM   #1 (permalink)
Default 95 Discovery, leaks coolant only when A/C is on?
I just bought a 1995 Discovery.. I noticed the day I bought it, right after I picked it up I filled it up at the Shell station and noticed coolant dripping out from under the truck (before I parked the truck, the A/C was running). I didn't have a long drive ahead of me, so I topped it off and drove home, but WITHOUT the A/C on and noticed that it had completely stopped leaking.
Fast forward to today, the same thing happened again. Drove it with the A/C on, parked it, and it leaked. Then drove it with the A/C off and it didn't leak.
What on earth would make it leak water/coolant only when the A/C has been running? This couldn't possibly be the condensation, because its green like coolant.
Any help would be greatly appreciated!
5speeddisco is offline   Reply With Quote
Old 05-31-2007, 03:18 AM   #2 (permalink)
cdcom's Avatar
Was your rover running hotter with your ac on???
1996 Disco 1
Chris........
cdcom is offline   Reply With Quote
Old 05-31-2007, 05:19 AM   #3 (permalink)
how about the green dye added to the freon.
Old 05-31-2007, 07:22 AM   #4 (permalink)
No, it was running the same temp as normal. And I doubt it was the green dye in the freon, because I'd think all the freon would have run out but I'm sure it hasn't because the A/C is still cold.
When leaking, the water drips from a hose on the left side of the motor (when looking at it directly) under the A/C compressor and whatever else is under there.
Old 05-31-2007, 05:36 PM   #5 (permalink)
Update, drove it around today with the air con on full blast, and it didn't leak a drop. wierd.
Old 06-01-2007, 02:39 AM   #6 (permalink)
Ian Matthews
p76rangie's Avatar
Have you considered that it may be condensation from the air-con unit rather than coolant.
Old 06-01-2007, 03:03 AM   #7 (permalink)
cdcom's Avatar
running the AC will tax your cooling system a little more than without, possibly pressuring a hose fitting to leak. If you've identified the the hose where it is leaking, try replacing it along with the clamp.
1996 Disco 1
Chris........
Old 06-01-2007, 09:09 AM   #8 (permalink)
cdcom, I do believe thats the case. I think it's mainly affected by how long I drive and the temperature out. I'll have a look later.
Old 06-01-2007, 10:03 AM   #9 (permalink)
When are you going to do what you need to do, that being have a pressure test done on the coolant system.
All this driving around and posting and you could be toasting your engine. Get it over to a shop before you drop a sleeve.
