Links
Old 04-25-2008, 10:44 PM   #1 (permalink)
Default 95 discovery will not start, help
my 95 discovery will not start. has spark and fuel pressure in the fuel rail but cranks with no sign of wanting to start. it quit while driving at highway speed. any suggestions?
bobm7007 is offline   Reply With Quote
Old 04-26-2008, 07:05 AM   #2 (permalink)
Elemental's Avatar
Gasoline Otto Engine No start/Misfire Diag Principles.
Old 04-26-2008, 02:07 PM   #3 (permalink)
I had a 95 D1 and the same thing happened. It ended up being the potentiometer and the temp sender along with the ECU coolant sensor.Is it a 3.9? I've got all the part numbers for this.
StJarvi is offline   Reply With Quote
Old 04-26-2008, 02:39 PM   #4 (permalink)
how did you test those items
Old 04-27-2008, 07:14 AM   #5 (permalink)
it makes a big difference if its a 3.9 rather then a 4.0. One has a distributor and one doesnt. if it doesnt have one, check the MAF, alot of times when it goes you will die on hte road.
95 Lr Discovery 1 Crank No Start lostinny Discovery Series I 10 12-22-2007 08:56 AM
1997 Discovery XD Serg Land Rover Vehicles 45 02-09-2007 07:47 AM
97 Discovery cranks but won't start BeattyD Discovery Series I 4 06-16-2005 06:28 PM
1995 Range Rover 4.0 Won't Start troverman Range Rover Classic 10 01-18-2005 05:33 AM
'96 Discovery hard start Rick Lindsay Discovery Series I 4 12-02-2004 06:06 PM
