Old 10-18-2005, 06:41 PM   #1 (permalink)
Default '95 engine ticking - any suggestions?
There is a ticking noise coming from the engine of my '95 Discovery.
Just wondering if anyone has any ideas what it might be before I
take it in to be diagnosed. I'm new to the forum, and it's great to
be here - very informative, great site. - Mike
discovermike is offline   Reply With Quote
Old 10-18-2005, 06:48 PM   #2 (permalink)
MG
me.guevara's Avatar
Welcome To LRO, Mike!
We'll need a bit more info on the issue to really help you out...
Cheers,
________________________
MG
'95 Disco I, 3.9L V8i 5-speed
Discoverying Bolivia...
Old 10-18-2005, 07:19 PM   #3 (permalink)
Default Thanks for the welcome
The ticking comes from the top of the engine block and
when it's most prominent when it's idling. When I press
the gas, the sound is much less noticable.
Old 10-20-2005, 08:34 AM   #4 (permalink)
Default RE: '95 engine ticking
Mike,
I had a similar issue with my '95 . The cause was the ligher oil that was used when the weather warmed up. It would tick after the engine warmed up particuarly at idle. I changed out to a heavier oil, 5/50 or 20/50 synthetic and the tick went away. When I picked up the rover the origianl owner had 5/30 synthetic but it was in cold weather. Once it warmed up it was just too thin. That was 2 yrs ago, no problems since switching oil. I hope that helps.
KF
kferg is offline   Reply With Quote
Old 10-20-2005, 11:49 AM   #5 (permalink)
Series Moderator
onslow's Avatar
Hi Mike welcome to the forum!how many miles has the motor wound up?
Cheers ONz
Old 10-20-2005, 12:22 PM   #6 (permalink)
Banned
Common problem with the 95's. The 3.9L motor has an issue with the rocker arms. When they start to wear, they get just enough "play" in them to cause a tick. It's nothing to be real worried about, but can be fixed.
Some people have luck by just re-torquing the rocker shaft assembly. Just pull the valve covers (they prolly leak anyway, right), and re-toque the bolts.
Worse case, you need a new rocker assembly set. You can pick them up pretty cheep used, <100.00.
Or, as mentioned, add thicker oil to cover the problem up....
Hank is offline   Reply With Quote
Old 10-22-2005, 06:46 PM   #7 (permalink)
Default Thank you for the suggestions
Right now, she has 68,669 miles.
I just bought it last week, and it probably hasn't
been driven in a while.
I only have a 60-day engine/transmission warranty.
But I also want to be able to work on it myself.
I changed the oil and put 10W-30 synthetic blend.
Should I have used full synthetic?
I'll retorque the rocker shaft assembly.
How many foot-lbs should the rocker arm assembly
be torqued to?
I really appreciate it, Mike
Old 10-22-2005, 09:01 PM   #8 (permalink)
Mike, check for leaks on the following,
the heads, the valve covers, the timing cover.
if it is bad try to get them to warrantee it.
