Old 09-05-2008, 07:20 PM   #1 (permalink)
Default 95 fuel pump prob?
I have a 95 v8i disco. When driving on the highway the engine will stall and quickly recover. This happens about every 3 to 5 miles. I've replaced rotor, cap, plugs, and wires. I checked for codes and there were none. Tested tps and it was ok. I checked fuel pressure and it was around 27 and when the motor (hickupped) the pressure would drop to 15psi. Has anyone had this kind of problem? Any help would greatly be appreciated!
jls5085 is offline   Reply With Quote
Old 09-05-2008, 10:19 PM   #2 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Check the fuel pump and the fuel pump relay. If you jump a short around the relay, and the problem disappears, youhave a hiccuping relay.
inert facts.
Old 09-07-2008, 07:48 AM   #3 (permalink)
does it hiccup if the vehicle goes over a bump, try shaking the relay.
it could be a loose connection or an open one that is getting bumped/
Old 09-07-2008, 11:25 AM   #4 (permalink)
I bypassed the relay and drove the truck about 5 min. no hickups at all. Then the service engine light came on. I pulled over and put the relay back in. The problem immediately returned. I have two relays on order that will be here next week. Hope that's the problem. Thanks for your help guys!
Old 09-12-2008, 02:46 PM   #5 (permalink)
I've changed the fuel pump relay and the problem still exists. Do I need to change the fuel pump now?
Old 09-12-2008, 10:55 PM   #6 (permalink)
The Urban Motorist
Check the pressure level of your fuel pump,read your codes, reset the ECU and read your codes again. Your codes should give you plenty of clues.
Old 09-29-2008, 08:34 PM   #7 (permalink)
I changed the fuel pump and it fixed the problem. Thanks for everyones help. This site has helped me alot with my truck!
Old 10-08-2008, 07:14 PM   #8 (permalink)
Hey ,, just wanted to add .. You might want to remove the fuel pump harness ,,to the pump + make sure to look at the base of the wiring pins + make sure they are not brown.Will need a new harness ,,if they are ..
Wayne1ss is offline   Reply With Quote
Old 10-08-2008, 07:22 PM   #9 (permalink)
next time you suspect the pump tape a fuel pressure gauge to the windshield and drive around and observe it.
HELP!! Fuel Pump??? Truck still on trail. bluemax09 Discovery Series I 14 02-22-2006 04:40 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
Fuel pump/ Fuel tank issue. Militant-Grunt Discovery Series I 9 12-07-2005 09:54 PM
No start, No power to fuel pump, ECU? Tiderover General Land Rover Discussion 2 09-17-2005 03:24 PM
Disco 1 Fuel Pump + Fuel Pump Relay Toddicus Land Rover Parts and Accessories 0 11-24-2004 01:42 AM
