Old 03-26-2005, 11:27 AM   #1 (permalink)
Default 95 Transfer Case Neutral Alarm Question
Hey guys, I recently took my 95 Disco auto into the trans shop after replacing the flex disc between the rear driveshaft and axle didn't fiix a vibration. The trans shop changed a hub in my transfer case and replaced my U-joints solving the vibration problem. After completing the repair, the alarm that comes on when the transfer case is in neutral stays on and my key won't come out of the ignition. To remedy this the shop removed a fuse to stop the alarm and get my key out- the problem now is without that circuit I cannot put it into low range and my overhead lights do not come on. This all leads me to ask- does anybody know where the neutral safety switch is at on the transfer case so that I could possibly bypass it?
Thanks guys for your time.
discodrew is offline   Reply With Quote
Old 03-30-2005, 08:41 PM   #2 (permalink)
k12
k12's Avatar
I'm not sure, but this site has pdf files of transfer case manuals. Should answer your question.
Good luck.
http://www.landrover.ee/est/varia/downloads/gearbox.htm
k12 is offline   Reply With Quote
