Old 08-13-2006, 04:54 PM   #1 (permalink)
Default 96 D1 No Spark Help!!!!!!!!
I have a 96 D1 ....I just put back together after having a valve job. I have fuel pressure at the rail but no spark at the plugs. I have power on 1 of the 5 ins in the coil pack connector. I'm not sure if that is correct or not, a common pawer and 4 separate grounds??? One for each pack? How can I test the individual coil packs and is there a way to test the ECM??? I had miss fire codes and sticking valves before the valve job if that makes any difference. Thanks for any help !!!! Tim O.
TIMO is offline   Reply With Quote
Old 08-13-2006, 05:08 PM   #2 (permalink)
crank sensor
Old 08-14-2006, 05:21 PM   #3 (permalink)
How could the crank sensor go bad just sitting for 2 weeks?? I said to myself, Turns out the sensor came unplugged inside the guard. Thanks Tim
« Trunk Rust | Help »
