96 Disco 1, where is the fuel temp sensor located?
Hey all- I've got a 96 Disco 1 with 178,000 miles. Put about 30k on it this year alone, along with a new water pump, O2 sensors, etc, all of the other things you'd think in a LR of this vintage. She runs great (knock on wood) but i'm having some hot starting issues and am replacing the Fuel Temperature Sensor.
So my question. In laymens terms, can anyone tell me where this sensor actually is?
Are you sure it isn't on the left side of the engine?
P. T. Schram Rover Repair
Full-service independent Land Rover facility
I ain't got much a nothing at all, but I damned sure got it made. If you don't like the way I'm living, you just leave the silly Rover boy 'lone!
Yeah, my PM box is full. If you want help, need parts, are on the ledge and need to be talked back, e-mail me at PT@PTSchram.com or call me at 260-804-0458.
If you don't like my attitude, I really don't care, but I will help you fix your truck anyway.
Thanks in advance.
After you replace the fuel temp sensor, you may want to pick up a crankshaft position sensor ($75 or so) as that is more often the reason for not restarting after warmed up.
It's progressive, it'll get harder to restart (hot)over time, after cooldown, often starts & runs great.
Both of mine suffered this two years apart.
Driver's side of engine, below exh manifold, covered by shield.
luck,greg
'96 RR SE - sold dammit
'97 D1 SE7 - I'll be buried in it
Like Flukey
Some bushings, Ford injectors, airtex fuel pump, timing chain , valve covers, crankcase scraped clean, side exhaust, twin 4" 110watts on bumper, sony, twin 12" electric fans, timing chain, guages, waterpump, no front sway, cut off front apron, 245/70/16 sumitomo all-terrains, front shock towers, shocks, starter, alternator, window reg mod, clean MAF, autolite plugs & autozone wires 50k and counting, front hubs, rod bearings, freed CDL, balljoints, Sony sound, u-joints, etc.
The fuel temp sensor is indeed on the LEFT side, threaded into the fuel rail just ahead of where it runs beneath the plenum. This can be removed with no fuel loss, the sensor does not actually contact the fuel.
While you are cleaning the throttle body it would be a good idea to remove the IAC and clean the pintle, and the seat in the plenum/throttle body. The IAC is held by 2 tiny bolts, 4.5mm socket IIRC. Be careful not to break them when you reinstall the IAC.
The crank sensor is $56 from Autozone, genuine part in a Duralast box. To change it you'll need a 7mm socket. Remove the UPPER bolt which holds the cover also, then unplug the sensor and remove the LOWER bolt. Reverse this to install the new one.
Well, I've got a new fuel temp sensor, but apparently that wasn't it, still having hot starting issues. It is on the left side, just in from the front of the engine. And no, you don't need to depressurize the fuel system to replace it. The biggest challenge was when the plastic housing of the old one pretty much deteriorated when I tried to remove it, had to use the good old vice grips to get it out of there...
I am going to hit Autozone on my way home, it's close enough that I should be able to restart once I pick up the part. I noticed Atlantic British has them for $56.95, but with shipping and how long it takes them to actually get stuff out the door, I don't have the time. I guess i'm going to have to replace this one from underneath? I'll find it. The Rave manual says you don't need to depressurize for this one either?
According to the Rave manual, "The crankshaft position sensor is the most important sensor on the engine." Maybe I should have started there!
Thanks everyone for the help, I will let you know what happens. I took some pictures of the location, etc, but am having upload issues. I'll try again later...
OK, replaced the crankshaft position sensor and still having issues. Got it at Autozone for $56.70, fyi. I'm out of my league witht he fuel pressure stuff, looks like it's going to the mechanic unless anyone has any other ideas? Drives like a dream, no other issues, except the starting when hot issue...
Your saying your having Hot starting issues what is the issue. It wont crank or it wont fire but will crank. Have you check your fuel pressure and any of the basic things like wiring ect?
Fuel temp sensor is cheap, drivers side on the fuel rail, if it is bad enough it should throw a code for it.
2nd owner of a '97 Disco with a ARB winch bumper, SD roof rack, Rover Racks ladder, Cooper S/T's and 220,000 miles on the clock and still a daily driver.
