4x4 Adventure Gear
I guess you could but how much cheaper are the 7mm than the 8mm?
John C 1996 DI - 3" AG lift 1995 DI - Scorpion Racing Extreme Kit 1991 RR - parting out (few parts left) 1990 Kawasaki KL650B Tengai 1989 Kawasaki KLR650 |
Does anyone know how well does Magnacore 8mm fit in the stock 7mm wire looms? I mean, can you make them fit, or do you have to replace the looms too?
Carlos Last edited by Carlos : 04-18-2005 at 09:35 AM. |
Super Moderator
Bigger is better to a point. With regards to magnacore, the 8mm & 10mm wires are the same. The difference is that the 10mm wires have a thicker silicon sheathing.
The Urban Motorist
![]() Join Date: Sep 2004
Hi from Adam in NYC
![]() Accel makes a new blue colored 8.5 mm with Double Shielding.....friendly for the engine and for your radio. I don't think they will have a specific set for Land Rover so you have have to buy the universal kit and make the specific lengths you need. Dont forget to buy the crimp tool so you can make the wires faster. I last used the Accel 9.5 mm yellow wires with the Bosch Plus 4s and when my old man drove my car, did he notice the acceleration. I had not done any other modifications other than the K & N airfilter. Afterwards, about 100 miles later, he wanted my secret recipe and he wanted his Ford done the same way (smile). I like it when a plan comes together Pep Boys in the US sells the yellow Accell but I think it will be a special order for the new Blues. Call ahead first unless you like to impulse shop. I think anything past 9 mm will be wasted unless you are planning on pulling the coilpacks and putting in a HEI discharge system. Its your money. |
I use the Taylors on all my junk, have for years, refuse to change. Indestructable. Fire-proof. The spark plug boots are molded to the wire, so there is very little chance of the fire "leaking out". The 8mm "rolls" well into the Rovers looms, and stays put. I also use silicone dielectric grease in both ends as a waterproofing measure. I used the universal V-8 kit that comes with two different coil ends that you install the best fitting one. I also bought a universal V-6 set @ the same time for a four-banger that I was working on, which leaves me with a "spare" for my spares kit, although I doubt that I will ever need it. Accels are great, and so are Magnacores, but if you have a source for Taylors, I have to say that they are probably the best! Good luck, LRW
#9 (permalink) | |
2001 Discovery SE7 -- Sold Thank God!!! Toyota Only Baby. |
#10 (permalink) |
Unless you're using a high energy coil pack, 7 or 8mm Magnecor wires are pretty much equal, and more than sufficient. Standard coil packs are only wound to give 20,000 to 22,000 volts, and 7mm Magnecors easily handle that without dielectric leakage. If you go to an aftermarket coil pack, of 35K or higher, go with 8mm. Shileded wires do absoloutely nothing unless the shield is grounded, preferably at both ends, requiring special plugs similar to aircraft or military vehicles, requiring RFI suppression. Always be sure to keep your wires free of oil, which breaks down rubber and silicone dielectrics. While oil itself has high dielectric properties, it causes the wire sheath to become soft, and then allows moisture to be trapped.
The best wires, commonly seen on aircraft engines, measure no more than 7mm and handle 50KV common on magnetos. a set of 8 (cyl, 2 per cyl) run about $300 per set, cut with connectors. I personally prefer NGK plugs over Champion, but am only one of many who feel Bosch Platinum yield nothing |
#12 (permalink) |
JMan:
I'm still deciding on whether do the endeavor task of changing the wires myself or pay the dealer $600 for new wires/installing.i see that it's not an easy job.How did you do it,andy special tricks? I have the rave CD and it appears to consume at least a day in doing so.My biggest fear is that if I have to remove the intake, I do have to deal with a broken gasket, do I have to install a new gasket after the wires are done? also do I need a torque wrench in order to put back the intake?Any guidance towards the project would help.I'm not in a position of letting go $600 for a set of wires plus installation. Thanks, Carlos |
#13 (permalink) |
Super Moderator
Why not measure the length of each of your leads, then contact your magnacore dealer and have them make a set for you in 8mm? I bet it will be a lot cheaper than $600.
#14 (permalink) |
Disco:
The problem is that if I do take it to the dealer I have to use genuine parts only, and they quoted me $25 a piece for the spark plug leads, and $600 total for the 8 leads plus the installation.Not appealing though... Carlos |
#15 (permalink) |
Super Moderator
Hi Carlos. I think I'm missing something here. Are you referring to the magnacore dealer or your LR dealer? Once you have the leads made up, you can install them yourself, just make sure you change them out, one at a time, so that you don't make any mistakes.
