FJL
Please help, The car starts fine, idles fine, runs ok at low speeds, but at highway cruising speed, after it gets heated up it begins to misfire and shutter. I have done the following to no avail. .......changed plugs and new Magnecor wires, fuel filter, changed front two 02 sensors. (there were previous codes suggesting the two fronts were bad) AutoZone detected the following codes, p0300, p0303, p1316. Someone mentioned something about a speed sensor on the D I's that is sometimes an issue but that wouldn't necessarily cause the faults as I was told. I disconnected the VSS and the symtoms remained so apparently its not the VSS. Anyone have any ideas what to do next? Thanks!
The Urban Motorist
![]() Join Date: Sep 2004
These codes are from www.troublecodes.net/landrvr/
P0300 Misfire on Multiple Cylinder P0303 Misfire on Cylinder 3 P1316 Misfire Excessive Emmissions Fault You got a problem with cylinder 3. Bad or loose plug, bad or loose wire, or heven forbid a bad coil pack. I dont think it is the coil pack since the coil pack fires into two cylinders at a time and there is no error for the other cylinder. Check the wire and the spark plug first.
-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=--=-==-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Owner of a 1996 Land Rover Discovery 1 in Beluga Black or the Dirt of the Day. Where we are going,we don't need roads. Nothing in education is so astonishing as the amount of ignorance it accumulates in the form of inert facts. ‘The Education of Henry Adams’ (1907) ch. 25 |
| Thread Tools | |
| Display Modes | |
| Code 1176 Maximum Positive FMFR Correction Fault Disco I | wade | Discovery Series I | 9 | 04-24-2008 02:14 PM |
| Disco 2 - TC & HDC fault lamps lit | rpbonnici | Discovery Series II | 1 | 03-11-2008 03:08 PM |
| [All] Pre 96 OBD1 Fault Codes | TerryS | Tech & DIY | 0 | 01-26-2007 07:00 AM |
| obd two codes | Rovin4life | Discovery Series I | 4 | 12-25-2006 09:16 AM |
| 0BD 2 code list | Rovin4life | Range Rover P38, Mk III and Range Rover Sport | 1 | 12-19-2006 06:43 PM |
