Hello all,
I am new to LR and recently purchased a '97 Discovery I. The PO installed a 2" lift kit from Ironman suspension, but otherwise the truck is bone stock. I'm trying to sort out a driveline vibration that occurs on acceleration in the 20-40mph range. By removing the driveshafts in turn I have isolated the problem to the front d/s. The shaft itself is fine, but the pinion angles seem to be way out from what they should be. The pinion is angled way up. I drew up the measurements. That file plus a bunch of other possibly useful photos are here: jagmandan/97 LR D1 high pinion angle - Page 1 - Photobucket - Video and Image Hosting From what I've read, with only a 2" lift the pinion shouldn't have come up this much. What are some possible causes for the high angle? It seems like the solution is a set of pinion-correcting radius arms to bring the diff down 6 degrees and then a new double-cardan driveshaft. What do the experts think of this diagnosis? Thanks in advance - any advice appreciated. -Dan |
Dan,
I have seen this before with that lift. The drivline angle is to great for the ujoints to work correctly. The best way is to fit a double cardon front shaft, either from a DII or from Great Basin Rovers , Tom Woods Driveline. I suspect it is at the worst right around the 30 to 35 mph range. charlie |
| Thread Tools | |
| Display Modes | |
| Can I drive an 02' Disco 2 without a front driveshaft? | 02Disc02 | Discovery Series II | 2 | 04-21-2008 06:09 PM |
| TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE | RedRhinoProducts | Land Rover Parts and Accessories | 8 | 10-16-2006 10:41 PM |
| U-joint | roverX | Discovery Series I | 2 | 03-22-2006 03:54 PM |
| 1999 4.6 needs some work; fix or sell? | Spring | Range Rover P38, Mk III and Range Rover Sport | 17 | 01-29-2006 02:18 PM |
| SG front driveshaft for sale | doc1911 | Land Rover Parts and Accessories | 0 | 08-12-2004 06:17 PM |
