OK, so I purchased the following from Rovertym:
2" RTE Springs Front Springs (Heavy Duty)-RR3 Rear Springs (Medium Duty)-RR4 OME Shocks Front Shocks (Heavy Duty)-N115 Rear Shocks (Medium Duty)-N46 Steering Stabilizer-SD11 I decided to go "heavy duty" in the front because of the Rovertym bull bar, Warn 9000, and a skid plate. I ran all of this past the saleman on the phone and he agreed with choices. A buddy and I put the suspension on and found that the front suspension ended up being a lot higher than the rear. It's almost as if the rear was not lifted (or very little at all) and the front had 3-4 inches of lift. What's the deal with this? Also, upon removing the front springs we found that the two were not even identical. One spring had less coils and was about 1 1/2 inches smaller than the other...??? The disco has approx. 120K miles. I noticed significant vibration coming from the rotoflex driveshaft - I'm guessing I need to do some mods down here to stop the vibrating? What do you guys think???
Sometimes you're the windshield and sometimes you're the bug |
Elephantitis penisitis
OK, welcome to the site and to the world of modding your rig. All rovers are different, some can go with a 3" lift and have no problems, some have problems with a 1" lift, they are all different.
1 - the springs are unmatched, as in they are set up for different sides to allow for weight, such as the driver, gas, and so forth. Send them back and tell them you want a matched set. Since they have not been used, they should do an outright switch with you, you will probably have to pay for shipping since it was not their fault - and if they do a switch with you, don't whine about paying shipping. RTE are great people. 2 - difference in height - front vs back - again, it's probably the springs you have. Call RTE and explain it to them. If you have the right springs, you will probably have to add a 1" or 1-1/2" spacer. Easy to fabricate if you need to do so or buy them for $60. 3 - vibration, like I said, all rovers are different. You need to replace your rotoflex anyway. Best thing to do and cheapest thing to do is get a driveshaft from a RR (late model) including all mounting hardware and slap that bad boy in. You can do several different things about the vibration, depending on where you live. LOL!!! If you are from Southern California, you will want to put in a TT in the front. If you live in the east coast, you will want to get new - crap, can't remember the name of the part! Well, anyways, I'm sure others will pipe in here.
Radius arms. That's the name of the part that escaped me.
#5 (permalink) | |
Rover you mention spacers, do you know anyone who uses them on a classic? I was looking at some, along with the upper shock mounts from Scorpion, the mounts would give me about 2-3 more inches of downtravel. Thanks
Beer is proof that God loves us and wants us to be happy. ~Benjamin Franklin 1989 RR Classic 1969 Series IIA 3 Kids in College...........
#6 (permalink) | |
I think they can be used on a classic. If not, just fab some. How noisy are the Scorpion upper shock mounts? I have heard some that are so clangy that it sounds something breaking doen there.
#8 (permalink) | |
4x4 Adventure Gear
John C 1996 DI - 3" AG lift 1995 DI - Scorpion Racing Extreme Kit 1991 RR - parting out (few parts left) 1990 Kawasaki KL650B Tengai 1989 Kawasaki KLR650 |
#9 (permalink) |
Thanks everyone for the reponses. You guys are like a free technical support hotline...
I'm going to call RTE and see what they say. I kind of like RoverX's comment about putting spacers in the rear to even the lift out. I like the heighth and the look of the front end, but not now because it looks like my disco is popping a wheelie! Anyone know where to get set of spacers 1" to 1 1/2"? Will I need to make any adjustments any where on the rig because of the added lift? Also, any hints on a replacement rotoflex if I can't find a used one?? Thanks again.
#10 (permalink) |
Whelp, called Rovertym...they said "make sure you didn't put the rear shocks on the front and vice versa"
Sure enough, that was the case. I'll swap them and let you guys know. Check out my signature - it applies here!
#11 (permalink) | |
4x4 Adventure Gear
#13 (permalink) | |
Oops, you're right! As far as replacing the rotoflex, I meant replacing it with a RR driveline with u-joints, not teplacing the rotoflex with a newer one. Sorry if I wasn't clear on that one. ![]()
#14 (permalink) | ||
Rover junkie
Mike '98 disco with rte and 33's '07 jk rubicon.......pretty much stock Remembering A.Stevens #13739 Quote:
