Old 11-04-2004, 07:33 AM   #1 (permalink)
Default 97 Disco Stalling/Dying
I have a 97 Disco, and recently it has started just dying for no reason. The tank is full of gas, and there are no funny noises, it just stops, usually when I am braking or at a stop sign. Has anyone else had this problem?
ilovevodka is offline   Reply With Quote
Old 11-04-2004, 07:44 AM   #2 (permalink)
beer drinking member
dent's Avatar
is your check engine light on? if so, try and get the codes read off and let us know what codes you're getting
take care
sam
dent is offline   Reply With Quote
Old 11-04-2004, 09:26 AM   #3 (permalink)
Air lines cleaning, throttle plate cleaning.
Ignition tune up?
Fuel filter?
Stepper motor (IAC) cleaning?
Flooding injectors?
Fuel temp sensor?
Coolant temp sensor?
Air flow sensor?
Fuel pump dying?
One or all of above.
Sergei is offline   Reply With Quote
Old 11-04-2004, 01:44 PM   #4 (permalink)
Default Dying Disco
Thanks for the replies.
The check engine light is not on, and we just had it serviced so we are not sure what the problem is. I guess I will have to call the rover dealer.
Old 11-29-2004, 12:54 PM   #5 (permalink)
Default Stalling at stop signs
Hello I was looking for stalling info for my 95 disco and saw your problem. I had an 87 classic that would stall after it warmed up but only after I drove at a constant speed mostly stalled at stop sighns and light after I got off the hughway. Any way it turned out to be the tranny. clutch material from automatic clutches. I asked if i should do a tranny service but my mechanic said it would make it worse because all the material would come out with the fluid. Check the tranny fluid.
crowbar is offline   Reply With Quote
