Old 05-10-2005, 01:49 PM   #1 (permalink)
BeattyD's Avatar
Angry 97 Disco starts once then won't start
Yesterday this problem began with my 97 Disco. It will start once if cold if I do not touch the gas pedal. If it does not catch on the first try, it will not start unless left alone for 30 minutes. The Engine cranks fine. It does not help to pump the gas pedal. I have to leave it alone for around 30 minutes and then will start so far if I do not touch the gas pedal.
The Disco has 92K miles and had regular service done to it. I am running Pen Sync 10W30 oil and the oild change was done 2 weeks ago.
Any advise would be greatly appreciated. I am afraid to drive it to a repair shop since if it stalls on the way, I could be stuck beside the road for 30 minutes or more waiting for it to get ready to start again.
Dave Beatty
beattyd@yahoo.com
BeattyD is offline   Reply With Quote
Old 05-10-2005, 03:22 PM   #2 (permalink)
BeattyD's Avatar
Question 2 Fuel Filters on a 97 Disco ??
I talked to my brother-in-law about my problem. He said it sounded like a plugged fuel filter. I look at my CD copy of the repair manual and it sounds like there are 2 fuel filters. One near the engine and the other near the fuel tank. Is this true ??
Any advise would be appreciated.
Dave Beatty
beattyd@yahoo.com
Old 05-10-2005, 04:22 PM   #3 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Lightbulb My two cents....
Dave Beatty
beattyd@yahoo.com
If you are sucking something in, it would be in the gas tank. The external fuel filter is in the rear passenger wheelwell. If there is debris in the tank, it would clog the fuel pump in the main tank. There should be a trap in there for large unwanted items.
Then you have to drop and drain or use a pump to drain the tank and then clean it. Personally, I would go into the rear loadspace and look there under the carpet.
I am thinking of something else. Then you restart the second time ,is there a click only the second time or is the starter turning the engine over?
I am thinking either the power cables to the battery are loose or the heavy connections to the starter need inspection/retighting/replacement?
Adam in NYC
Old 05-10-2005, 05:05 PM   #4 (permalink)
BeattyD's Avatar
Question
No Problem with the battery or the starter. The engine turns over fine.
That is why I suspect the Fuel Filter.
From the CD Manual... it appears that are 2 Fuel Filters.
True ??
Dave Beatty
beattyd@yahoo.com
Old 05-10-2005, 05:07 PM   #5 (permalink)
BeattyD's Avatar
Thumbs up
I just called NAPA and they said they only show 1 fuel filter so that will be my first stop when I get off work.
I will post an update when I know more.
Dave
Old 05-10-2005, 08:48 PM   #6 (permalink)
BeattyD's Avatar
Red face
Looks like the fuel filter for my V8i Disco is the frame mounted one that is near the fuel tank on the frame rail ??
I got one so now I need to climb under the rig and get dirty... Yuck.
Any advise ??
Dave Beatty
beattyd@yahoo.com
Old 05-10-2005, 10:41 PM   #7 (permalink)
Super Moderator
Disco's Avatar
Yep! To prevent getting dirty, lie on a ground sheet!
Old 05-11-2005, 09:28 AM   #8 (permalink)
BeattyD's Avatar
Thanks for the Tip. I have even a better idea. I invited Brother-in-law to dinner tomorrow. He works on cars for a hobby. He has a 57 Chev wagon that he restoring. I used to do auto repair work when going to college. I used to make fun of customers (behind their backs) that paid to have oil changed. Now I am too lazy and I am the one getting most repair work done for me.......
Old 05-12-2005, 08:37 PM   #9 (permalink)
The Urban Motorist
Lightbulb Don't forget...
to properly lubricate or feed your brother-in-law.
Old 05-12-2005, 09:53 PM   #10 (permalink)
BeattyD's Avatar
Well ... Here is the update.
Brother-in-law installed new fuel filter.
..No improvement, vehicle would not start.
Brother-in-law replaced spark plugs which appeared to be original (92K miles)
..Some improvement. Vehicle starts but has no power and is back firing.
Next step is to try to drive vehicle to repair shop since will run at low speed.
Suspect problem with coil. Have triple checked the spark plug wires.
coil 1 - 1 and 6 cylinders
coil 2 - 5 and 8 cylinders
coil 3 - 4 and 7 cylinders
coil 4 - 2 and 3 cylinders
Did have to go with Champ Spark plug RN11YC4 since NAPA did not have RN11YCC and NAPA said RN11YC4 was a valid replacement.
Real strange problem. Vehicle ran fine 2 days ago.
Any advise appreciated.
Dave Beatty
Old 05-13-2005, 06:00 PM   #11 (permalink)
BeattyD's Avatar
Thumbs up Problem solved.....
Problem was a plugged throttle body (area right after the air filter) and PCV Valve. The Dealer that I bought the Disco from spray some polish like material to make the engine look shiny and this gummed up the engine alot.
Had the rest of the 90K Service done.
I was pleased that the total invoice was $1000 for the full 90K service (The dealer quoted me $1100 for just the 90K service) including fixing the backfiring and loss of power issue. The also replaced the rear brakes with rotor turning....
My Baby is well again. All is well with the world.
Dave Beatty
