Originally Posted by BeattyD
I talked to my brother-in-law about my problem. He said it sounded like a plugged fuel filter. I look at my CD copy of the repair manual and it sounds like there are 2 fuel filters. One near the engine and the other near the fuel tank. Is this true ??
Any advise would be appreciated.
Dave Beatty
beattyd@yahoo.com
If you are sucking something in, it would be in the gas tank. The external fuel filter is in the rear passenger wheelwell. If there is debris in the tank, it would clog the fuel pump in the main tank. There should be a trap in there for large unwanted items.
Then you have to drop and drain or use a pump to drain the tank and then clean it. Personally, I would go into the rear loadspace and look there under the carpet.
I am thinking of something else. Then you restart the second time ,is there a click only the second time or is the starter turning the engine over?
I am thinking either the power cables to the battery are loose or the heavy connections to the starter need inspection/retighting/replacement?
Adam in NYC
