New to the board ,
I have a 98 Disc. for eight months now. When I first got it, it ran fine, then after a month it would hesitate off and on the HWY it would drop about 500 rpm and jump back up again ever 1/4 mile. Checked under the hood I notice that vacuum line on the valve cover breather was bad so I replace both, problem went away. Great ! A few months went bye and again some problem this time I removed the little plastic part thats in the valve cover breather hole and removed the carbon build up on it. Ha problem went away. Well now its back again and checked everything I did before and it's not working. The truck seems to run fine in park and I hold the rpm high no hesitation at all, but anytime I drive over 30 it starts up again. Any advise out there ? Thanks |
Super Moderator
Could be a number of things. Check your fuel filter as this could be semi clogged with crud, especially if you have run the fuel in your tank low. if the fuel filter checks out ok, you should have a look at your spark plug leads as they could be on the way out.
Lets know how you make out.
Supremei,
I have a '97 Disco that is hesitating on and off and it only happens after I have been on the hwy for 25 minutes or so...Have you diagnosed your problem yet? Thanks, Tirewall |
Try unplugging speed sensor, you will lose your speedometer, odometer, but it should tell you if that is the problem. As far as both of you, like me, I have a 96, these have the adaptive memory on the computer. If you have changed the air flow inside the engine, this will change the fuel/air mixture. The computer cannot re-learn the new mixture. You may have to get the adaptive memory purged. This WAS my problem, WITH the speed sensor. The cost was $75.00 at my independant Rover Tech. Feel free to contact me if you have further questions.
Eric The Red 93 Range Rover Classic ![]() We will never "arrive" so the goal is to keep moving forward on our journey so we can periodically declare, "I am not what I want to be, but I am not what I used to be!" 96 DISCO SE7 5-SPEED SOLD ![]() ....okay couldn't live without a disco!96 DISCO SD 5-SPEED -ARB Bumper -OME 2" Lift -2" spacers -Safari snorkel -15" steelies
That is pretty much a dead giveaway!! They cost about $100.00 I got mine at roverconnection.com
I been having same problem going to try to remove speedo and see if it helps. but I havent noticed my speedo droping or anything when it happens it just kinda stays where its at,.
Stock '96 Disco v8 100k Miles Upgrades: Optima Yellowtop Battery Switched to synthetic engine & power steering fluid. Garmin 176 GPS CB |
#9 (permalink) |
My Speedo never changed either. Sometimes, if it is real bad, the speedo will jump up and down. I had thought about this some time last year. Since the speedo didn't jump around I had dismissed it. Did more checking, and just decided to unplug it for a while. What do you know, it worked. Good luck
