Old 10-07-2007, 08:20 PM   #1 (permalink)
Default 98 Disco 1 for 1900 bucks Good Deal?
Have a chance to get a 98 Disco 1
Auto
cold climate
7 seats
Rear air
dual sunroofs
135K
Lights on Dash abs brake Needs brakes grinding
Cracked exhaust manifold
power steering leaking.
Runs fine drives fine cdl works all widows lights work
does have rust on the rear door jambs
Was buying to set up to go wheeling what do ya think
New to this seems like a good deal.
Thanks in advance
1900 out the door
02 Disco
Ohio disco 2 is offline   Reply With Quote
Old 10-07-2007, 08:33 PM   #2 (permalink)
01001010's Avatar
Gallery: 15
Hek Yess!!...buy It!..now..go!
JC...
Old 10-08-2007, 12:30 AM   #3 (permalink)
Ill sell you my 96 d1 with 94k miles for 3500 its needs brakes and othing more runs like a champ
bigd2010 is offline   Reply With Quote
Old 10-08-2007, 01:04 AM   #4 (permalink)
01001010's Avatar
Gallery: 15
Dang....not a bad deal either! Makin it difficult for the guy..haha
JC...
Old 10-12-2007, 09:03 PM   #5 (permalink)
flunkster's Avatar
to fix the abs-pull the fuse and be done with them...they suck (sorry chris)!
the power steering leak could very well just be those damn cheap ass hose clamps again.
for the cracked manifold...look up roverguy.com (will tillery) for a used replacement. make sure to have the mating surfaces milled as they can be warped.
the rust is another story. i would look carefully at the rust situation. pull the rear cargo carpet and the pass and drivers kick panel/carpeting. you can always grind/weld and por-15 if its not too bad. look at the frame too.
sounds like a decent deal though....if the rust if stoppable.
flunkster is offline   Reply With Quote
